Question about Kenmore 20172 Top Load Washer
Moving a top load washer once used
If I want to give my working ok kenmore washer to my sister 500 miles away can I transport it in an unheated truck bed in freezing weather --- or will it be damaged by residual water freezing inside? also can I store it in unheated shed for a month before trucking it from Detroit?
    President:
  • 1,314 Answers
If you have a wet dry shop vac you can pull all the water out through the drain hose till its dry don't think you would have any problems with the storage now shipping across country might be another thing when you got the washer new you had to pull the shipping pins a yellow tab with three cotter pins if you still had them you would need to replace them before shipping you would need to open the case and on the frame below the tub you will see three plastic cups with little pins in them you have to push them back up through the frame and replace the cotter pins to lock the lower frame to the upper tub frame or it wont ride good at all
Posted on Feb 12, 2008
TRANSPORTED IN PICKUP TRUCK, A KENMORE SERIES 500 WASHER. GUY PUT IT ON ITS SIDE FOR THE TRIP. NOW ITS NOT SPINNING PROPERLY. COULD TRANSPORT HAVE DAMAGED IT?
is it new or used --if new notify for return / replacement if used yes transporting on side can cause stability problems
Jul 11, 2017 | Kenmore Washing Machines
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
Top load kenmore elite washer manual
OK...What is the Question? Here? If you need a Manual . Call Sears. They practically give them away or tell you where (ON their web site) to view one! I did not observe a structured QUESTION here! So I hope I helped
Feb 26, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I need to transport a front loading washing machine a 3 miles distance. I know that front loaders require a stabilization kit, but given the short distance, is it really necessary?
with the machine unpluged and freestanding from the wall.at the back of the top panel you will find two screws remove and slide the top off,you see a large cement block get an old duvou/heavy blanket and wrap it inside over the block and top of machine,keeping the drum and block as tight as possiable.dont forget to remove after moving.adrianxxx
Apr 02, 2013 | Kenmore 44072 Front Load Washer
Just want to know if its ok to lay my new washer on its side for 7 to 10 days while I transport it in my van its still in the box
Should be ok. It has oil in the transmission but if it is new then the oil shouldnt leak out. However I used to work in a parts dept and i have seen new transmissions that were on their sides leak out. But they werent attatched to the washer.
Nov 29, 2011 | Kenmore 24032\24036 Top Load Washer
We are moving to a new house (just three miles). How critical are the transport instructions for the He2 Plus washer?
The mount system is important to stabilize the tub during transport, if your careful you can move this without them. To prevent damage, you can remove the top, pack the unit with blankets to prevent banging around, and damage to control panel inside. Just be careful and this can be done without damage to the unit.
Good Luck
Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
How do you service elite for transportation
Transport pins that lock the basket in place.
That is all.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Overloaded Washer
Sounds like you broke it. Ha Ha. You got $500 to fix it. Conspiracy!!!! The machines are at war with us. 'Eventually, people become slaves to the items they aquire.' Power to the people!!!! Death to the machines!!!
Aug 07, 2009 | Kenmore 24032\24036 Top Load Washer
Installing transport bolts
yes there is you best to remove the 3 screws holding the top on slide back remove then you can move the drum around usley have someone pull up install bolt
Feb 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 20172 Top Load Washer Logo
60 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
