Question about Sony PlayStation Portable (PSP) Console
Lens problem when i first turn on my psp and put in the umd it works but if i go back to home and try and put it in again it does not work and the lens does no turn on and the lens moves to much which makes a clicking sound. when the psp works with a umd and i do system restore a couple of times the lens seems to stay on for a while enabling me to change umd and play a multiple amount of umds but after some time it goes back to the lens not turning on and the umd not working. the lens seems to turn on when it likes what can i do? please help thanx
Try cleaning your umds and blow out your psp with compressed air
Posted on Feb 13, 2008
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
Starting direct to umd and hang
If u don't want ur psp to start automatically when turning it on u can change it in the system system settings
To run the UMD smoothly yo need to:
a) Try cleaning the UMD with a clean smooth cloth gently...
b) Try cleaning the psp's umd drive (where the lens is)...
c)Put the umd properly in the drive...
Mar 13, 2011 | Sony PSP-3000 Black Console
Umd no longer on psp screen and can not play my game`s.
try turning it off then putting the umd in, then turning it back on. if that doesnt work, there might be a problem with the disk reader
Aug 10, 2009 | Sony PlayStation Portable (PSP) Console
Disks wont read
First try cleaning the lens. Mine got dust on it, and it stopped reading UMDs.
A little rubbing alcohol and a q tip and it might work.
use 70% alcohol to clean the lens. Use that stick that you clean your ears with. And use not to mush alcohol. Let the lens dry for 10 minutes and try to play a UMD disk again.
If that doesn't work and still under warranty just send it in and they'll fix it for you :) Good luck!
Jul 29, 2009 | Sony PlayStation Portable (PSP) Console
My psp won't load umd's and all i hear is a scrathing sound
The UMD laser might be dirty or broken. Open up the UMD drive and give the laser a clean with a lint-free cloth. Then pop the disk back in and try again. If that doesn't work, you will need to get the PSP repaired or buy a replacement laser and do it yourself.
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
Chipped psp 3.80 m33
try turning the psp completely off.
Now turn it on while holding the R button.
that should bring up the recovery menu.
Hit
Advanced> UMD mode M33 umd iso.
Apr 03, 2008 | Sony PlayStation Portable (PSP) Console
Psp
Hi Glenpark, Eithr the UMD or UMD laser is dirty.  If it will play other UMD's the UMD is dirty.  I think Gamestop has a device that helps broken and dirty UMD's.  If it will not play any UMD, then you have a problem with your UMD laser.  You can try to clean your laser lens.  Use a Q-tip.  Dampen, not soak,  a Q-tip with a window cleaner. NOT Alcohol. Swab the lens thoroughly with the cleaner, then use the dry Q-tip to dry and polish the laser. Try hard to not leave any lint.
If you UMD still does not function, you need to send it back to SONY. Contact them at 1-800-345-7669.  If you cant get them to fix it Contact The Playstation Clnic at Repairtech@Playstationclinic.com
Oct 27, 2007 | Sony PlayStation Portable (PSP) Console
Psp
is it a scratching scrapping noise?
as some UMD cases, as in the plastic thing around the disc colapse or come apart this stops the disc spinning properly.
Check the plastic on the UMD... click any sides together that may be loose / or make sure the case isnt pushing on the disc.
Also open the PSP, hold it upside, gently shake it & blow into it.
Put the UMD back in & try again.
Oct 03, 2007 | Sony PlayStation Portable (PSP) Console
My UMD icon dont appear when i put a game on it
I think the lens might have died permanantely, or maybe just it's temporary. I've also had the same problem, and one time I turned it on, it started working again. Wait about a day and see if it still happens.
May 18, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
63 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
