Question about Kenwood KDC-MP228 CD Player
Pm228 ok ive had this mp228 in my room for 2 years now ,i hate to just throw it away. i had my car at a garage to have the fuel pump changed and when i got it back the stereo no longer worked??it will take a cd i dont think it does anything... its been 2 years since ive messed with it.. do you have any idea what could be wrong,ive checked the little fuse in the back its ok?
  • johnnytai Feb 13, 2008
    there are no lights on the face and i dont hear anything going on iside of the radio....but it will take the cd and eject it on command,other than that nothing.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Make sure your power wire is secure. Do you get a display? Is the speaker wiring still good? Any corrosion around terminals at the back?
Posted on Feb 12, 2008
Does the easy starter assembly include the spring.Part no.310022001
My experiance with these is that they are a throw away item as people hate working on them. Do yourself a favour and get a husky. My reason for this is reliabilty. I have owned a 524l for 6 months and reliable as ive also owned a 132r for 30 years that did the rings but for 30 years with minimal maintanance i think that speaks for itself. Dont muck around with this cheap chinnese rubbish. It will cost you. Both now and in the long run
May 06, 2015 | Homelite Mighty Lite Lawn Trimmer
I replaced the crank sencor and its still throwing a code
The car only blue books for about $3000. I hate to suggest it but financially it may be better to cut your losses on this one. A used engine with 7000 miles on it for this car could have been purchased for $1200.
The code that you are getting does not necessarily mean that the crank sensor is defective. Those codes are to be used as symptoms only. If the crank sensor is bad the car won't run at all.
If it's running rough you need to check the health of the ignition system, fuel system, and the timing.
Starting with the easiest to the more difficult.
1. Pull the spark plugs and read them. Are they fouled/damaged/wet/burnt?
2. Check the engine compression. Is the compression low?
3. Check the timing marks. Did the timing belt slip off a tooth with the cam gear? Is the timing belt worn out? Make sure these marks line up with what your manual shows.
4. Check your fuel pressure with a gauge. Does it match what the manual states it should be?
5. Is the coil pack weak, out of tolerance? Check it with a multimeter, make sure the ignition wires are in good shape. If you've never changed them, this would be a good time.
If you check these things you should find the problem...throwing parts at it till the problem goes away is the most expensive way to fix it.
Nov 27, 2012 | 2001 Nissan Sentra
What's your problem?Hi I have a 90 convertible mustang 5.0. My problem is the fuel pump wont shut off when you turn key on. It runs and runs and car wont start. Ive checked all injectors, changed
Dear Charlie,
May I suggest you take the car to a good (old?) mechanic and have it "changed?".
Right now the fuel pump is hooked to the battery directly, which is why the pump will not turn off.
Please have him hook the pump up so it only runs when the ignition is on.
God bless your efforts.
Sep 07, 2017 | 1990 Ford Mustang
Not getting fuel will not start put startingfluid in air intake motor will try to start
Fuel pumps bad! Unless you have a clogged fuel filter!! Have great spark?
Sep 04, 2011 | 1989 Mercury Tracer
After driving it doesnt want to start,acts like its not getting gas ....ive already changed the fuel pump,and the fuel pump relay,took it in for a diagnostic,but nothing is showing up,garage said they...
Is it a diesel engine? if so, there may be water in the fuel filter which needs draining out. Whether it's diesel or petrol there could be an air lock in the fuel system, particularly in the engine bay (check that flexible fuel pipes are not routed too near hot engine components like the exhaust). If they have been disturbed recently for servicing, they may not have been repositioned under the clips that keep them away from hot components.
Dec 25, 2009 | 1997 Isuzu Rodeo
Fuel Filter Clogged? - 1998 Toyota Avalon
this year car have 2 filters: one inside fuel tank that generally not to change until not change fuel pump, and other external at engine room that changes aprox every 20k miles
Apr 05, 2009 | 1998 Toyota Avalon
Intermittent problem will not start /fuel pump system problem
if you run it under a quater tank you will continue to replace them the fuel keeps them cool and lubricated i know it sounds weird but its true ive bought 2 in as many years at600 a pop keep it @ a 1/4 to 1/2 and you shouldnt have to replace it again after this time
Nov 19, 2008 | 1996 Chevrolet Astro
Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Mike
Oct 12, 2008 | Toshiba 50HP66 50 in. Plasma Television
Kenwood KDC-MP228 CD Player Logo
41 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
