Question about Toshiba 62HM95 62" HDTV
Toshiba 62HM95 has sound, but picture turns off after a few seconds
I turn the TV on and I have picture and sound. After between 5 - 20 seconds the picture goes away, but the sound stays. It seems like it is a heat issue, but I am unable to find the problem. I took it to a repairman and he was unsure which of two components it could be. Finally after two weeks of looking at it, and supposidly talking to Toshiba, I told them I need to know something soon and magically they determined it was the light engine, but they didn't seem too sure of themselves. Now since it is home again, it appears that there are vertical lines just before the picture goes out. Does anyone have any better guidance or has anyone else seen and corrected this issue.
  • 3 more comments
  • masm Feb 13, 2008
    Extra info - The lights on the front show that everything is normal. No flashing lights or anything abnormal, just a steady red light. I also have a brand new bulb that I installed and that didn't help either. Any ideas?
  • masm Feb 16, 2008
    I've heard it is easy to replace, but I've opened it up to try to determine how easy it would be, but I am not sure which piece is actually the light engine. Do you have a picture or detailed instuctions on how to replace it.
  • LBiggity May 20, 2008
    When I turn on the TV, I get sound sometimes, but no picture.  Then the TV automatically turns off, and turns on again a few seconds later.  The process repeats itself until I turn the TV off.
  • garyndianf Jul 09, 2008
    yes
  • masm Nov 17, 2008
    I have the 62HM95 and my light engine went out between 2 and 3 years. I will never buy a Toshiba again. I have had nothing but trouble with the components and the customer support. I am in a class action lawsuit with them, but I doubt very much will come of it.
    As far as fixing your TV I was in the same delimma as you. I wasn't willing to pay nearly $1000 to get this set repaired when it already cost $3000 and it started having problems within the year and major issues after 2-3 years. I was willing to risk a couple hundred bucks that I could fix it myself. If you aren't very handy with taking things apart and putting them back together, by all means don't do this. It is pretty easy to do and you can figure it out as you go, but I wouldn't suggest you doing this if you weren't willing to take the risk of really messing it up.
    I didn't go to Part Store.com because they wanted $456 and then when I finally decided to do it they raised the price to $556...No way, I found http://www.tristatemodule.com/html/light... and you can get a light engine that is refurbished for $250, or you can have your light engine refurbished for $200, which is what I plan to do if this one fails in the next two years. I looked at their site and it doesn't show that they have any in stock, but they may if you call. I wasn't comfortable sending mine off to be refurbished because I wasn't sure if I would remember how to put it back together, and I'm glad I didn't because the one they sent me didn't work, which sucks, but it happens. I called them back and sent it back to them and it worked fine. All in all, I had no instructions or any other help besides my memory of how I disassembled it and it only took me an hour at the most, not really too hard.
    The only other issue I had with them and it really wasn't with them as much as Toshiba is, I received a light engine for a 46" model, which when I talked to Toshiba they swore up and down that it wouldn't work, when I talked to TriState about it they said that Toshiba would say that and they had used it in 1,000's of 62" models and it's worked fine. After they replaced the broken one they sent originally, the new one worked fine and is still working brilliantly and I have my original 62" light engine to get refurbished if anything should happen again. Their shipping time was good and when I returned the product to them, I received a working part pretty quickly.
    For $250, this would be the only way I would go. If this hadn't worked, I probably would have just went out and got a different TV. I hope this helps.
    Michael
  • 50 Answers
Did you change the light engine? If not they are very easy to do, you can do it yourself.
Posted on Feb 16, 2008
I have a picture and no sound when watching just the tv. However, if I hook a dvd to the tv there is sound.
Check to see if you SAP has been turned on. This can cause a no audio symptom on TV. Button should be on the remote, or go in to audio options in the user muenu.
Jul 14, 2011 | Toshiba 62HM95 62" HDTV
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
My Toshiba 62HM95 DLP TV does not work with my PS3 via HDMI or Component cables. Is the TV not compatible or is something wrong?
hello, unplug all the cables from you ps3, turn the power off on the ps3 then turn it on press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleep relase the button, also turn your tv off then on again, when your ps3 comes back on plug the hdmi cable into your ps3 and then into your tv hdmi 1 on the tv go into the menu find hdmi click on this you should get a picture and sound hope it works
regards
shaun
Nov 22, 2010 | Toshiba 62HM95 62" HDTV
Connecting stellite receiver to 62hm95
hello when you conncet the satellite put the main aerial in to the satellite receiver R1 the a second lead from R2 to the tv. also you may have to connect a scart lead from the satellite to the tv this should take you to an av channel automatic good luck
regards
shaun
May 07, 2010 | Toshiba 62HM95 62" HDTV
Tv turns off green light flashes twice and no
It trys to start but no picture? That means it's time to replace the lamp.
Apr 30, 2010 | Toshiba 62HM95 62" HDTV
Shuts off and on no picture but sound ok
you need to be more especific about the TV model? brand, etc...
Apr 15, 2010 | Toshiba 62HM95 62" DLP HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
No picture
Hello pravinp,
Since this is a DLP set, The bulb becomes suspect. I would take the bulb out and measure the voltage in the socket from which the bulb was taken to determine if the socket is hot. If it is I would then take a resistance reading of the bulb, the resistance should be at 0 ohms. If your bulb is blown replace it with the exact type. The TV might be shutting down to prevent further damage from occurring
I hope this helps
Shuttle83
Dec 21, 2007 | Toshiba 62HM95 62" HDTV
Picture seems to be alot darker than before. toshiba 62hm95
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Feb 23, 2007 | Toshiba 62HM95 62" HDTV
Toshiba 62HM95 62" HDTV Logo
535 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
