Question about HP ScanJet 3670 Flatbed Scanner
Scanner light When I'm trying to scan you can hear it start but then it stops completely and the light never comes on
  • bobbyathwal Dec 17, 2008
    scanner turns on and windows after about a minute gives me a message to check lamp
Bought a new scanner.
Posted on Feb 13, 2008
ABS and Trac Off lights are on along with service trac. control message. tried to scan with my snap-on scanner and i get a NO COMMUNICATION message
check for power at obd2 port for scanner possible blown fuse ,the abs and trac off will come on if you have abs sensor bad most common issue,
Dec 10, 2014 | 2005 Chevrolet Impala
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    When i install scanjet 8270 on windows 7 professional.after complete they appear hp solution center on deskotp and photosmart. so the problem is when i try to scan documents or picture or other alse the...
    Hi
    Please go to the control panel and select the Scanner and Camera, hear you get your scanner, double click the scanner and try to scan the paper, if hear also give the same error then please reinstall your scanner driver,
    click hear to download the driver
    May 19, 2011 | HP ScanJet 8270 Flatbed Scanner
    Why does my HP 1500 prints a test page every time I begin touse it???
    HI
    As soon as the printer prints the test page or alignment page place it on the scanner glass (Place the printed side down) before that Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
    After That press scan on the printer button panel it will resolve your issue.
    Try to double check it by turning it off and turning the printer back on after 2 minute's. If still the problem exists call HP Total Care 800 - 474 - 6836 if you are from US/Canada.
    ) Lift the lid of the product.
    2) Place the top of alignment page face down in the right front corner of the glass.
    3) Place the alignment page face down
    4) Close the lid.
    5) Press the Start Scan button.
    6) The Power button light will blink during the alignment process.
    7) After the Power button light stops blinking, alignment is complete.
    Aug 04, 2010 | HP Office Equipment & Supplies
    Scanner stops partway along path, motor whines
    There is an obstacle in the scanner path, or the scanning head guides got bent (unlikely). There could also be something in the rubber drive belt driving the scanning head gears. Try looking inside with a light and check for scratches on the guide. Unfortunately, to fix the problem you'll have to either send the scanner to maintenance, or to open it yourself (voiding the warranty).
    Oct 30, 2009 | Canon CanoScan LiDE 90 Flatbed Scanner
    MP 160 Cannon Printer Won't Scan
    try checking if you have completely installed all the drivers for your printer. scanning and copying dont usually needs drivers because you can do that even without a computer. but scanning requires your scanner to be read by your pc. try checking for the scanner driver from the cd that came from your printer.
    Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Scanning error - cannot scan error code 2,155,0 ???
    i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
    here is the link : http://www.fixyourownprinter.com/forums/printer/49111
    Thanks
    Sanjieev
    Jan 13, 2009 | Office Equipment & Supplies
    Scanner Canon 5010c
    This is a known problem with the scanner. Use PixEdit to scan which comes around this problem so the scanning terminates OK after the ADF goes empty.
    Dec 22, 2008 | Canon DR-5010C Path-Through Scanner
    I cannot get any stations to come in on my scanner for police or fire and emergency frequency.
    check the antenna connections first,does it scan but not stop? or does it stop but you hear nothing?If it stops and you hear nothing try the headphone jack and see if you can hear anything there, if so its the speaker or audio amplifier. if it scans but does not stop try removeing the antenna and putting it back on to see if it has a good connection.
    Dec 10, 2008 | Uniden BC340CRS Base Scanner
    HP ScanJet 3670 Flatbed Scanner Logo
    98 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
