Question about Jenn-Air JMC7000 Microwave Oven
Makes load noise and wont heat anything
Out of the blue my microwave started to make a loud noise when you press start and it wont heat anything
  • csbuceo Feb 21, 2009
    I replaced the diode but it won't metal butter. Lights are on, table moves, fan is working, and the display is working.
  • Jenn-Air Master
  • 9,098 Answers
I would first suspect a shorted high voltage rectifier diode or possibly a defective magnetron.
If the noise is just a loud buzz, I would suspect the diode. If it has more of a hollow sound - like someone gurgling into a coffee cup - then I would suspect the magnetron.
Here are some links you or a friend can use for test help, but PLEASE read their safety warnings first:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ... > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
This morning my microwave started making a loud noise and wouldn't heat. Is there anything that can be done?
Replace it. Not work the risk of tampering with since microwaves are relatively inexpensive now. They are made to be disposable.
Feb 01, 2011 | GE Microwave Ovens
Loud noise and not heating up
if its making a loud humming noise you need to remove the outer and carefully discharge the high-voltage capacitor in the magnetron circuitry(caps are usually oval in shape and 3 to 5 inches long) after this disconnect one terminal of the cap and check it for being open,then do the same on the high-voltage diode and check this for front to back resistance high in one direction and lower with the meters leads reversed on the diode,the humming is coming from the transformer not being loaded by the cap and diode to double the voltage required by the magnetron tube of -2,000 volts D.C.
Apr 26, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Jan 31, 2009 | GE JVM1860 Microwave Oven
Microwave won't heat
Microwave Oven Basic Troubleshooting Tips
Apr 14, 2008 | GE JVM1653 Microwave Oven
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
237 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
