Question about Eddie Bauer Lightweight Travel System 01-750-AFD
Missing harness for carseat/carrier
I received this second hand and it is missing the part that snaps into the carrier to hold the baby in place (the straps are there, just not the piece). Is there somewhere I can order a replacement part?
  • 4 Answers
Www.babybuisness.com has long list of strollers repair centers and places that carry replacement parts, they should have some in your area. Hope that this helps!
Posted on Feb 18, 2008
How do you put the footmuff on the maxi cosi carseat?
Open the carseat harness and have the carseat in front of you so you\'re looking at the seat. Slide the shoulder harness pads down the length of the harness and off over the harness clips. Unzip the footmuff and place it into the seat and thread the harness through the holes at shoulder and crotch position. Replace the shoulder harness pads onto the harness. You can now place your baby in, do up the harness + tension correctly, then zip up the footmuff to keep baby cosy.
If you\'re still using the headhugger/lumbar support wedge this can be used underneath the footmuff.
Nov 06, 2012 | Maxi-Cosi CabrioFix (Black Reflection)...
PIERRE CARDIN BABY CARRIER
Hi
Due to the safety implications of the carseat harness being incorrectly fitted if the harness has been completely removed from the carseat shell it would need to be sent to engineers for them to re-fit the harness. What country are you in we can direct you to the appropriate customer care team to arrange this.
Feb 02, 2012 | Maxi-Cosi Cabrio Red Flame Reflection...
Footmuff instructions
Hi Beth - First open the footmuff, and set the carseat down on the floor in front of you so you're facing it. Take the harness pads and ****** pad off the harness straps and place the footmuff into the carseat. Pull the harness straps through the holes in the footmuff and press the back of the footmuff into the curve of the carseat. Replace the harness pads. You're ready to go! When you use the carseat, simply put baby in and do up the harness as usual, then do up the footmuff for cosy, safe travelling.
Nov 24, 2011 | Maxi-Cosi Baby Gear
I need instructions for the genki house baby carrier and for the bubba moe baby sling
Here are Genkihouse Sling instructions - I tried to attach scanned copies of the instructions, however it exceeded the file size limit:
For front use
  1. Hold your baby close to your chest
  2. Still holding baby close to your chest, grab sling and place over baby - Genkihouse logo facing away from you, arrange baby's legs through leg openings. Alternatively, you can lay the sling on a change table with logo facing down, lie baby on top and put legs through leg holes then lift the baby and the sling onto your chest.
  3. Still holding baby close to you, place sling straps over your shoulders.
  4. Reach behind with one arm (still holding baby with the other) and firmly take the strap from behind opposite shoulder. Your other arm still holds the baby and sling.
  5. Thread the strap through D ring with one hand whilst your other hand still holds the baby.
  6. Simply 'hook' the strap through the D ring with your index finger.
  7. Do not change hands at this stage.
  8. Tension strap backwards - away from your back and don't let go.
  9. Feel the baby's weight now firmly supported by the sling at your waistline.
  10. As you continue to hold the same strap reach behind with the other hand and thread the second strap through its D-ring. The straps should criss cross over your back.
  11. Bring straps together, adjust tension to suit and tie a secure knot in the middle of your back.
  12. Check the position of the baby - you should be able to kiss his/her head.
  13. Baby can also face outwards when he/she gets older.
Jun 15, 2011 | Baby Gear
Can i place the car seat facing front?
Hi - If it is an infant carrier Group 0+ carseat it must never be installed facing forwards. It is designed as a rear facing carseat to keep your child safe in the event of an accident. Always install a carseat according to the instructions.
Feb 21, 2011 | Maxi-Cosi 22371HFL Infant Car Seat
Hi, weare missing the bars that fit under the
If you purchased the carseat without the bars, then this is a Cabrio and not a CabrioFix carseat, and nothing can be done to adapt this to become a CabrioFix.
I hope this helps.
Aug 14, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
I am having trouble figuring out how to snap my saftey 1st
Discontinue use at once! Safety First is not on the list of carseats that this model supports, according to the chart in the instruction manual.
Jul 15, 2009 | Baby Trend Snap N Go 1308 Stroller Frame
Graco Snugride Carseat postion in 1304tw Babytrend double stoller
Visit Baby Trend to download a pdf manual from strollers for you specific type of stroller. http://www.babytrend.com/
Check the instructions to learn how the seat should be attached. Did say doesn't work for all brands.
Jun 10, 2009 | Baby Trend Snap-N-Go Frame Stroller Frame
I got a used car century car seat but the harness is not installed right and there is not enough harness there. can i buy just the harnesses? where would i go to get them?
Anytime your carseat is missing part or incorrectly assembled you should contact the manufacturer. There should be a number located on the back of the seat. If not google the company and contact them directly. Most of the time they will send you the missing part. If your child is too big for the seat they will also let you know and could be able to send you a bigger harness kit. You may end up paying for it but you could also get it free of charge
Mar 27, 2009 | Century Encore 5-point Harness
Car seat straps
ON THE BACK OF YOUR CARSEAT ARE 2 METAL LATCHES ON EACH SIDE. REMOVE ONE BE PUTING THE STRAP THROUGH AND ADJUSTING IT TO YOUR CHILDS FIT.YOU COULD ALSO PUT IT THROUGH A SECONDARY HOLE IF YOUR CARSEAT HAS ONE TO PROPERLY HOLD YOUR CHILD SAFELY.LET ME KNOW IF I WAS ANY HELP...
Jun 03, 2007 | Evenflo Chase Comfort Touch
Eddie Bauer Lightweight Travel System 01-750-AFD Logo
141 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
Douglas Dinnebeil
Douglas Dinnebeil
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
