Panasonic turntable sl h205
Arm won t lower, also if I use auto setting instead of manual , the table stops turning although the motor arm is turning. Had been in storage awhile and had worked.
  • 26 Answers
Check the belt and the cueing mech, could have siezed.
John w
Posted on Feb 14, 2008
At end of play, arm swings to neutral, but my Technics TT SL-D20 turntable continues to turn for a couple minutes, than stops and is ready to play again.
There is a adj screw back by the arm however it is a bit hard to set best is to try a very little turn only one way to see what changes, the screw should be under a small plug near the arm base or table base I don't remember much about that model, sorry if I come up with anything else I will post.
Sep 25, 2014 | Audio Players & Recorders
Technics sl 1200 dragging
almost often a wrong set table/arm weight and a dirty needle. . i gues the last. Cleanen record
May 13, 2014 | Technics SL-1200 Turntable
My arm won't lower onto record, the arm lowewring mechinism won't lower
After my THIRD Ion turntable had the arm-lowering problem...
I rotated the platter counterclockwise about 12 times and it worked...for now. I'll keep my fingers crossed and hope it wasn't a fluke.
Dec 29, 2011 | ION Audio iTTUSB Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
The arm just slides across the record.
The link for this model's manual is a dead-end at the Panasonic website. I lodged an email complaint.
If the tonearms balance and anti-skate are set properly it should track correctly.
When you lower the tonearm does it actuallu drop onto the platter or does it seem to hover? Look at the stylus to make sure a dustball hasn't clogged the tip.
Jan 19, 2011 | Technics SL-BD20D Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
The tone arm will not drop on our Technics sl-dd33 turntable.
Have you left the tone arm lift in the up position?
If not: At the end of a record the mechanism lifts the tone arm, returns it to the rest, lowers it and switches off the motor.
It the motor has stopped too early, the tone arm will remain raised.
You can try gently rotating the platter clockwise by hand. This may allow the return cycle to finish.
Jan 16, 2009 | Technics SL-BD22 Turntable
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
127 people viewed this question
 Grubhead
Grubhead
