Question about De Dietrich 22 in. DTV315 Electric Cooktop
De Dietrich DTV315 - Suddenly switching off
My De Dietrich DTV315 while cooking, it suddenly stops and all lights on the panel (even those for the hobs not working) start flashing. This occurs occasionally and w/o following any pattern. When this happens, it takes anything between 30minutes to 2-3 hours to be able to restart it. The technicians came in, but they didnt manage to find the problem, as the problem couldnt be re-created while they were there. They have checked the connections and they said that everything was ok. Pls advise as it is driving me crazy.
De dietrich induction hob dt1304je1
Sorry if you can not find it how are we going to . it is something I have never heard of in the USA
Aug 08, 2015 | De Dietrich Cooktops
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
GE cooktop ignitor jgp
Look for a short in the wiring (usually white wires running to the ignitors) or a loose ground wire. (usually green)
Jul 02, 2012 | GE Cooktops
My cook top is beeping nonstop ! i overboiled some whater and it fell on the cooktop. now it is beeping all the time ! what should i do?
You need to contact your dealer. Tell them to fix it or replace it. Boil over water should not affect an induction stove top.
Jan 09, 2012 | De Dietrich Cooktops
On the instalation of a de dietrich dti714v does it simply sit in the worktop hole? only supported by the glass lip?
there is a foam seal to fit between the glass and worktop and there should be some brackets that go underneath to hold it firm.
basically the glass does sit very close to the worktop.
Mar 14, 2011 | Cooktops
Light stays on in De Dietrich oven DOD438 all the time. It is in the lower oven. Stays on whether door is open or closed. Oven is new since May 2007
I too have just had this problem. The door switch (top right corner) is broken and the oven thinks the door is always open. Chances are it won't heat up either.
Apr 05, 2010 | De Dietrich 22 in. DTV315 Electric Cooktop
Suddenly I hear a constant 'clicking' sound from the Maytag csg7000 cook top which I am not using right now. It's like it's trying to ignite by itself. What could be a problem?
usually this is a problem with one or more of your ignitor switches, they are found below the selector switches, below the top, if you take off the selectors you might even be able to see them,
these are what sends voltage to you ignitor, from the spark module, one one goes bad, they all tend to spark, because light one light all....
http://www.appliancepartspros.com/part_details.aspx?part_id=4101545
this link wil take you right to the part i suggest,
as well as be able to order it
since this happens alot after a boil over i would start with one of the front two burners,,,, you can order one and keep replacing them with the next till the clicking stops
Nov 04, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
Element on cooktop will not switch off
Probably the contacts at the switch are welded together. I suggest removing the switch and if found to be so, separate and clean with a small bit of fine sandpaper.
Jun 21, 2009 | De Dietrich 22 in. DTI305W Electric...
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
De Dietrich 22 in. DTV315 Electric Cooktop Logo
50 people viewed this question
Top De Dietrich Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a De Dietrich Cooktop Expert? Answer questions, earn points and help others
