Question about HP LaserJet 4350 Printer
HP 4350n Printer says paper jam .
The message says paper jam in tray 2, but nothing is visible. We have removed tray, replaced paper, looked with flashlite, felt with hands, turned machine off and then on again.
  • 1 more comment
  • Anonymous Mar 06, 2008
    I DID EVERYTHING THAT SAYS ON THE INSTRUCTION BUT STILL THE SAME PROBLEM.
  • rollyno1 Mar 07, 2008
    My printer says jam in tray 2,but I can't see anything that can be the obstraction on the paper path.
  • Rich Weinhardt May 11, 2010
    What is the number of the error?
    New Friend:
  • 159 Answers
Check the paper sensor maybe one of the sensor stuck
Posted on Mar 17, 2008
HP officejet printer 8500 is giving erroneous paper jam messages! What's the problem?
>Remove back cover(duplex) check any paper object jammed? remove it.. >remove paper tray observe any paper objects visible? remove it>Check paper path sensor located at the path of carriage assembly.. observe for free play of sensor flag...
Jan 30, 2012 | HP Office Equipment & Supplies
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
HP Deskjet D4100 1) The arrow pointing down near the power switch is flashing. Printer will not print. 2) The printer goes "offline" Paper is not jammed, have unplugged/plugged. rebooted numerous...
First, here is a link for the troubleshooting your printer: https://support.hp.com/us-en/product/hp-deskjet-d4100-printer-series/501868
I always go the the manufacturer website to download drivers. I also just had a similar problem on our printer at church. Two people looked and looked after pulling a jammed paper out of the printer. I looked a few times, opened the 2 back doors, the front door, removed the paper trays and looked, opened the side door, and looked again. Each time the printer said jam. I got a flashlight and looked everywhere again, nothing. Still said jam. I looked one more time in above where the paper trays go, and under a piece of plastic just barely visible at just the right angle was a tiny scrap of paper, not much bigger than a quarter. I managed to get it out and all works fine. Possibly you may have something like this going on?
Dec 22, 2017 | HP Deskjet D4100 series
How to clear paper jam?
How to clear the jam depends on where the jam is.
If the Jam is in Tray 1:
1. If you can see the jammed sheet, remove the jammed sheet by pulling it straight out.
2. If you cannot see the jammed sheet, open the tray 1 door and pull out tray 2.
3. Push down on two tabs to release the tray 1 panel.
4. Remove the jammed sheet by pulling it straight out.
5. Push up on two tabs to replace the tray 1 panel.
6. Replace tray 2.
If the Jam is in Tray 2:
1. Pull out tray 2 and place it on a flat surface.
2. Remove the jammed sheet by pulling it straight out.
3. Replace tray 2.
4. Press OK to continue printing.
If the Jam is in the Fuser area:
1. Open the rear door.
2. Remove any jammed sheets.
3. Close the rear door.
If the Jam is in the Output Bin:
1. Look for jammed paper in the output bin area.
2. Remove any visible media
3. Open and then close the rear door to clear the message.
It is possible that the paper may tear when clearing the jam. Be sure to clear any paper fragments that tear off.
Dec 16, 2010 | HP LaserJet CP1515n Printer
Paper jam message no paper jam cartridge gets stuck HP 6310 all in one
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | HP Officejet 6310 All-In-One InkJet...
Paper jams
hi,
follow these steps:-
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
Aug 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
How do I clear a paper jam?
hi,
Thanks!
Aug 02, 2009 | HP DeskJet 932c InkJet Printer
How to remove a paper jam from the vivera paper tray
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting the printer manufacturer for additional assistance and/or repair.
Jul 13, 2009 | HP Photosmart C7280 Laser Printer
Cut off printer during print, paper jam tray 2 won't release
Open the cartridge door and remove cartridge...can you see the paper here...if so slowly apply even pressure to both sides of paper and pull...
keep me posted
Cheers!
Nov 13, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 4350 Printer Logo
367 people viewed this question
Ben Johnson
