Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
Port forwarding i need help to forward a port for notopia router, and i have lorex security camera system hooked through at&t dsl
  • ToniQ Mar 08, 2008
    My son has XBOX Live but it will not let him play due to strict NAT. I was told that I would need to forward ports to the XBOX Live in order for him to play, how do I do this?
  • Jagan Mohan
    Jagan Mohan May 11, 2010
    hi
    what i the model number of the netopia ???
  • 51 Answers
Check this link for port foward configuration
cheers !!!!!
Posted on Feb 13, 2008
I can't seem to remotely connect and view my lorex cameras. What am i doing wrong...it was working fine till I got Verizon FIOS
You may need to reopen the ports necessary for the Lorex to be available for remote viewing. You should be able to look at the function on the Lorex menu to get the port numbers, then call Verizon to have them forward the ports. Without port forwarding, your video stream is being blocked at the Verizon FIOS Modem.
Feb 01, 2013 | Lorex Home Security
Westell 7500 set up guide
modems are not routers. Routers can port forward. You need your WAN to face your ISP, and your LAN will need to face your router. Once you have your router talking to your ISP you can set it up to hand out interal network services, but I doubt SOHO routers will do port forwarding. Routers, however, can do port translation like passing gaming traffic over port 80 (web). You can do that in the security tab on your linksys.
Jan 13, 2013 | Westell Wirespeed Westell 7500 Dsl Modem...
I am trying to get my servailliance camera hooked up via the internet. I am not getting a picture and I guess I need to set up a forwarding port on my router. How do I do this?
Look at the brand of router and model router and go to their web site. Down load / read the steps to log in to your router. Enter the URL link or IP , then user name and password. Look through the setup for a section that is labeled port forwarding. I've worked with several home consumer routers and their all web based and look pretty strange at first but study it and your see how to tell the router to forward a port to a specific IP. But that will only work it your computer always connects with the same IP on the router and that you always use that same computer to see your camera. Routers by default are DHCP and assign you an IP at random when you connect. Port forwarding would require you to also setup your computer to static IP, Meaning you MAC address would always be assigned the same IP, so the port forwarding would always be able to forward to the correct IP. Sounds much harder than it is. Your question sounds like you want to ensure the camera ip/port is passing through the router, so your home computer can see the video. Thats how you could forward a port to something. But if your wanting to see your camera from anywhere on the web then you'll want to make sure your router isn't blocking that port to the open WAN (wide area network). But I'd check your firewall on your computer FIRST>. Thats all a firewalls is for. Try connecting to your camera with your firewall / anti-virus software off for a test first. If it works then you need to be setting up your firewall on your computer and not your router. Firewall is usually part of your anti virus software and or, part of windows. Go to control panel, look for the security shield icon on XP and disable the firewall. You'll get some errors, but this is just for a test. I can't remember exactly the step for windows xp, but again look for help on your operation system of google it. Also don't forget about the lights on your router. Use them to help troubleshot. Went you plug the camera in, does the activity light come on? You can also have a bad cable...... good luck!
Apr 01, 2011 | Linksys Wireless-G WRT54G Router
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
I need to access a remote LAN through the internet. our church office is on verizon DSL with a westell 7500 modem. I have security camera's attached through an Ethernet cable. I need to be able to use...
You need to install a software that will manage your LAN's video recording. That software should work fine within your LAN and is usually provided with the Video Capture Cards where your cameras are connected. This software should have a web portal for you to access via internet utilizing your forwarded port. Thus, you must tell your video software to use your forwarded port for internet viewing. Without this web portal, you can't access your remote LAN videos via internet.
Feb 01, 2010 | Computers & Internet
I have 2 lorex dvr's. both need web access, can it be done
there are a few ways to accomplish this. one way is you will need more then one static ip. one static ip for each machine, you will then be hitting them on the same port but different ip's. the simplest way is to change the web port setting in the lorex dvr from 80 to something else in the second machine.
Dec 22, 2009 | Lorex 4 Channel Business & Home Security...
CAN'T CONNECT TO THE STORE CAMERAS FROM HOME PC
at the deli you need to port forward in your router the web port witch is normally 80 to the ip of the machine.
Dec 15, 2009 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
Can't log on remotely
did you set up a port to connect through if not you need to set one on the port your DVR needs and forward it. It is called port forwarding.
Sep 29, 2009 | Home Security
Problem with post forward
I HAVE ONE OF THIS ETHERFAST CABLE/DSL ROUTER BUT I CAN INSTALL...CAN YOU HELP ME????? PLEASE
Feb 03, 2008 | Linksys EtherFast Cable/DSL Router
How to port forward th 2 wire router from web port 80 and tcp/ip port 6100..?
Hi, Here is a manual explaining how to do it... lorexstore.lorextechnology.com/ pdfs/SG19LD804-161_CLIENT_MANUAL_EN_R2.pdf -
Aug 01, 2007 | 2wire (1000-400108-001) Router
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
383 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
