My mp3 player does'nt want to accept files or delete them.
When i send files to it,it says it is write protected
my usb device cant take any folder or files
I'm trying to spread the news on how I fixed mine just this morning with the same problem. I can't believe how many people have the same problem.
I have heard to format--didn't work for me. I have heard to switch the write-protection button on the side--mine doesn't have one.
I heard to make sure your mp3 is not in 'pause' or 'hold' mode--THAT WORKED FOR ME! It was so simple. I had been messing with the buttons so much I must have put it in pause. Please try it. Good luck.
OK, i had the same problem with my Micro SD when i tried to put in file in it it said write protectec and blahblah i took out the micro sd and i see Lock and i just turned that off and it worked :))
Righ click ___ Properties___Read only _UNCHECK the box
These are very primary solutions....pls suggest me something new. I have two flash drive with same problem...
I have a problem in my USB. when i past somthing in it there was an error of writeprotect. so what should i have to do for copy in it?
Yes people please help my zen stone plus doesn't want to transfer any more and i dont think i have a hold button. If you know a simple way of removing the write-protection without installing anything or whatever that would be great.
You guy could try this it didnt work for me but it could for yousome one claimed that it can take write protection off butit cant detect mine http://www.4shared.com/file/et8_It43/Repair_v2911.html
its called repair v2911 Hope it works.
To whom it may concern,
I have a 2 GB PNY attaché Optima Pro flash drive. When I try to save anything on the flash drive it tells me that it is right protected. I hate to destroy it and throw it away, because it's a good flash drive. I'm trying to get an answer from somebody on how to fix it. If you give me an answer. I really would appreciate it very much.
These are the primary ways that I tried.......would you pls suggest me something new... I have two USB flash drive with same problem
Right click from my computer and select - Open As Portable Device.
for some reason that let me access it. any other way its like bricked.
Right this had me vexed all of two seconds ago! i took it off hold and tried to format it, i even pressed play- 'this device is write protected'! then i growled at my computer some more before yanking the silly thing out and actually playing the music i had on it, so i put it in and the stupid thing works!! OMG what a pain!
I think a solution to all this is that if we all work as a team to solve this, it can be easy for all of us because everyone can come with an idea and we can see what we can do to that issue and it can be easy for eveyone to decide if it is a good idea or should we all try something else because if you just sit back and do nothing, none of your problems will be solved because you are not asking for any help from any one, so guys if you think that this story is useless just email me to tell me that is it good or not
this is my email address
[email protected]
you can send your comments at any time and you should also send your email address too..
khusta...
SOURCE: how to remove write protected
There must be a little tab somewhere, if you move it you unlock the write protection.
Sometimes it has a little padlock sign.
I am srinivasan.
While I format my usb device it says your usb device is write protected not able to format it.
I try it in linux also.here it says your file system is mounted as readony. Anabel to open it.
Please send me an email and guide me.
how to remove write protection on my usb device?
hello my flash memory 1GB i cant do anything cause of the write protected n i dont have any click in the flash so how i could remove the write protected plz :)
I have the scandisk brand usb 512mb flash memory. [not mp3 player] and it doesn't have any button for write/read protection. Now I have the same problem "write protected"....when I want to take or remove files from it. It can't be formatted. So what's the solution. I had a twinmosk 128mb also. I was damaged with the same problem..
when i send files to it or try to take them off it say wriiten protection
i reformat my MP# player.. but i cant format it.. i dont know what i do... ans. my question... what i do?
i can't able to save files to my usb it apears write protect
how to remove write protect on my usb flash drive problem
My File System is Now In RAW and not FAT32!! WHAT!!? There is no Right Click Properties to Uncheck a Read Only Box because there are no Boxes under properties for This Disk (all others there is) It's a PNY Attache 4GB and they have a LOW LEVEL Format Link that doesn't connect to anything except their homepage. Zero Help from them regarding their product.
I have a basic player, i.e., without microSD card, I have  just purchased it.Â
When I erroneously added .vob files it copied to the main memory but does not delete saying it is write-protected. Can anyone help me please to tide over the problem?
