Question about Canon PIXMA iP90 Mobile Printer
Paper in printer
My problem is that the paper in my printer grabs unevenly and the paper will not advance in the printer! This is the 3rd printer this has happend to. Is there a maintenance feature I can perform???
  • lollyjane Feb 12, 2008
    paper will not advance in printer...gets stuck. Can you help?
    thank you
    President:
  • 2,351 Answers
Goto the link provided below. You will need to fill in the three drop down windows.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Select cateegory = Printers
Select product type = PIXMA iP Series
Select model = PIXMA iP90
Click GO
Start with Number,
1.) Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Continue down till issue is resolved.
Posted on Feb 12, 2008
  • Mike Peluso
    Mike Peluso Feb 13, 2008
    I missed a section. After you click GO. The next page that opends find "Search Our KnowledgeBase". Type in the window, printer pulls paper unevenly and the paper will not advance Click Search.
    Issue: Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error). Check suggestions 1-5.
  • Mike Peluso
    The most common reason paper is taken by a printer unevenly is the printer's rollers are dusty/dirty. Second reason, there is something in the way at the feeder. (the place the paper enters the printer. Paper dust build up. This area you clean using a rag dampened with water.
Will not grab paper. says out of paper when its not
You can try cleaning the rubber wheels with alcohol. Sometimes they become covered in dust and won't grab the paper.
Apr 08, 2012 | HP OfficeJet 7410 All-In-One InkJet...
How do I clean the rollers on lexmark x2500
You can try to clean the rollers with a cotton bud to reach it.
Leading cause of paper misfeeds is debris or foreign objects that accidentally fell into the paper feed area. Grab a flashlight and look into the feeder for any obstructions.
Dec 24, 2011 | Lexmark X2500 All-In-One Printer
When I print, the paper gets jammed. The paper is grabbed on one side and goes in unevenly thus causing the jam.
Hello!
We must feed curved paper to our printer. To avoid paper jam let the paper be straight and dry... thanks
Sep 07, 2011 | Canon PIXMA MX310 All-In-One Printer
My copier will not pull the paper through to make copies it seems to want to jam -up ,when the paper start through
There are a couple of possible issues here. First, if the unit isn't new, the paper pickup rollers may have picked up 'chaf' from grabbing paper which over time reduces the ability of the rollers to grab paper. The 2nd option is that if the copier is older, the pickup rollers have dried up which reduces their stickyness and ability to grab paper. The 3rd option is that if you live in a very humid climate, the paper may have absorbed humidity, which can keep it from curling in the correct direction as its being pulled through the printer/copier.
Jun 20, 2011 | Computers & Internet
Printer paper feed
Hi there
This hapens a lot with different printers, best way is to gave your papers a good shake and keep in a worm place then it may work for you.
All The Best Pineworks
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Paper not feeding correctly
sounds like there is a piece of ripped paper in the printer
Jun 18, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Roller won't grab paper to start copy process
...you should try to reinstall your printer's driver...
Jun 01, 2009 | HP LaserJet 3050 All-In-One Printer
Canon i475D Printer
Try cleaning the rollers where the paper feeds in, a cotton bud with metho works on my printers
Apr 15, 2008 | Canon i475 InkJet Printer
Printer won't advance next piece of paper
You can get a repair kit for this off ebay.
Your paper feed roller and lifter are worn.
Jan 30, 2008 | HP LaserJet 1012 Printer
Canon PIXMA iP90 Mobile Printer Logo
177 people viewed this question
old marine
old marine
