Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Volume lowers while I am watching this TV, the volume, on its own, goes way down. It makes a noise first, then goes down. When it does this, the remote doesn't work to adjust the volume, you have to do it with the bottons on the TV. But, most of the time, if you shut the TV off, and turn it back on, it works again. There are times that you turn the TV off, and back on and it still doesn't work with the remote. The remote still operates all other functions.
  • 1 more comment
  • white kitty Mar 08, 2008
    i just posted the same problem!
  • TheBossT127 Mar 24, 2008
    Usually there is a loud pop followed by a reduction in volume. If one has the patience to wait, the volume will return to its normal level in a matter of seconds. Of course this pop usually occurs at a point in whatever you happen to be watching is in a critical moment, so I generally turn up the volume and then reduce it as it goes back to normal.
  • taylordo Dec 05, 2008
    two problems..1. TV doesn't respond to remote at times.
    2. TV pops then sound geos down and back up in a few seconds.
    Hello Zenith, where's the Quality?
    Problem Solver:
  • 17 Answers
Replace digital board. A hardware update is available that might solve it.
Posted on Aug 19, 2008
I get a popping sound on my tv when I change Chanel's
Check all of your audio and video connections to make sure they are seated(connected properly). After doing so,if you still have the popping sound try lowering the volume and see if the popping noise lessens or gets worse.If the noise goes away then you may have a problem with the speakers,either in the tv or in an external sound system if one is connected.
Feb 19, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
I have a constant ringing sound coming from the tv. It goes up and down as I increase or lower the volume by remote. As I change the audio option to "Spanish", regular "English" audio comes out on c
The fact it shows on tuner and not DVD means not likely a audio problem--check all audio settings in the set's menu AND if you are using a box for signal look there--has to be a setting.
Some JVC sets (brand indicated here) also had issues with when watching the background audio (like a sporting event) was louder than the people talking and could be interpreted as ringing--This is a setting in the set called something like "Theater" or "Hall"
Has to almost certainly be a setting in the set.
Mar 28, 2012 | JVC Televison & Video
My vizio tv is making a buzzing noise when I watch tv.. I tried turning the volume up on the cable box up and the volume on the tv down but it didn't help.. It's still making that noise.. This doesn't...
Hi, Mary with Dish Network Customer Service. I had this issue with my TV as well. You will need to turn the TV volume up and the cable volume down. The opposite way from how you have it now. This should resolve your issue.
Jan 24, 2011 | Televison & Video
My tv is a westinghouse model 26h730s and it has a buzzing sound when its off and when its on it has a annoying sound like when you go and get your ears tested but it is constint it is low and when you are...
Hello, normally this buzzing sound comes from the power supply, before you go out and replace the power supply for this noise try to lower the backlight, this might make a difference in the noise but also be very aware that your TV might be a little darker than before.
Jan 23, 2010 | Westinghouse Electric SK-26H730S 26 in....
Have problem with the volume in my rca tv
stuck tact switch is most likely the cause or the become leaky and conduct we change a great amount of them on those sets
Oct 23, 2009 | RCA F32650 32" TV
Buzzing noise when turning on the volume.
Only recourse is to replace the main cba. I would probably try ShopJimmy.com for the module because "IF" you could get one from Visio it would be anywhere between $200 - 300.
Apr 30, 2009 | Vizio L37 Television
Vizio speakers make a buzzing noise
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Tv volume goes down of its own accord
Some dust in the button to lower the volume on your TV or on your remote control might be causing it to think it's being pressed. Try playing around with it, pressing it hard so as to relieve it of any pressure on the inside.
Jan 09, 2008 | Televison & Video
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
