1996 Toyota Paseo Logo
Posted on Jan 20, 2010
Only one key fob works, the 2nd does not. i have changed the batteries. It is a TVSS 111B. When i bought car last week, a Rav 4 1997 the 2nd fob had no battery in it but i have put new battery in and still no led light on any other response from it. please help
cextence
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Jan 20, 2010
cextence
Contributor
Level 1:
New Friend:
Answers
6
Questions
Helped
2385
Points
15
Its going to be a bad remote.
1helpful
97 Toyota 4runner Alarm system DEI rattler 300
IMMO lamp glowing in UNHAPPY STATE SURE>
FOB H3LL been there too many times.
first off the fob batteries must be good. inside fob.
battery put in backwards has no chance ever.
never have just one working fob key on any car
or land here. x
off to the locksmith you go or they to you.
my fobs died here about 8 years old (new to now)
2 new once died, here just last week, 8 years old
1st the bottom switches inside gold wore off. dead.
no cure ever for that, !
2nd fob when berserk and has unlock command transmitted endlessly and its switch is shorted for ever. no fix for that. again.
and all failed every year for coin cell. every one.
never have just 1, or costs can go super high.
mine cost me $75 to make 3 new keys.(programmed)
(had new keys in hand me)
that is my advice, and how to be proactive
I have a proton s 16 2010 model it doesn't lock or open doors with fob but when I changed the battery for the car all the doors unlocked any one know what that would be
this is Australia's cheapest car;! we have no books on down under cars.(generic answers me, outside USA)
lost 2nd FOB?
and cars mostly have key that can open doors. even a key hiding in the fob.
or valet key?
the fob has a battery too on most fobs. a coin cell
lost the users guide? in the glove box.
car battery not put in backwards correct, Plus to Plus only !!!!!
head lamps on car work>? yes./no
try both fobs cars come with 2 never just 1,
some have valet keys too.
most have a fob battery .
12 year old fob coin cells are EOL this old end of life where present,.
1helpful
2answers
Mercedes key fob not working 2001 s 500
please take the key fob to your nearest advanced autoparts and ask them to pull out the battery for you. Then, you can test the key fob with the new battery. If it works, then your fob is fine. But if not, you would need to order a new key fob for your car.
Thank you.
My Porsche cayenne s key fob opens door automatically and crank engine but doesn't start it rather display immobilizer active
start by scanning vehicle for trouble code --fixing battery issue --resetting or reprogramming fob/security system
Saab 2003 key not recognized how to by pass to get it started
There's an antenna for the transponder receiver built into the key surround on the 9-5, it could have had a knock or be faulty.
On the 9-5 if the transponder stops working and you get a key not accepted message then you can override it by pushing the unlock button on the key remote with the ignition turned to on and it should let you start the car.
Both my keys FOBs on my 2000 Dodge Grand Caravan don't work, changed the batteries, still did not work. Bought 2 new ones and the dealer could not program them.
Programming a Replacement Keyless Entry Remote ' Filear ...
filear.com/?p=131
Oct 17, 2012 - If the transmitters don't work, or if you'd rather not match the transmitters yourself, .... Tried these instructions last night on my 2005 Grand Prix.
Key FOB Not Working - The Chrysler Minivan Fan Club Forums
forum.chryslerminivan.net/showthread.../11859-Key-FOB-Not-Working
Mar 15, 2009 - 10 posts - ‎3 authors
Hi Everyone, One of my Key FOB's stopped working. Is there a way of ... Well, to be honest, you don't know where that FOB has been? LOL ... 2009 Dodge Grand CaravanSXT (3.8L), Light Sandstone Metallic, 125K miles 2005 Volvo .... By jimmy154 in forum 3rd Generation Chrysler Minivans: 1996-2000.
Key May Not Start Car or Release From Ignition : Dodge ...
repairpal.com > Problems > Dodge > Grand Caravan
Dodge Grand Caravan Key May Not Start Car or Release From Ignition. ... If the newkey doesn't work, replacing the lock cylinder including tumblers ... I am able to turn off the van, but the key is stuck in the ACC position, draining my battery. ... In reading other comments, I see it may be the FOB so I'll carry both with me and ...
2009 Dodge Grand Caravan car lock doors not working
Key fob intermttant
Hi. Is this with both keys? If so then I suspect there is an issue with the immobilser. I suggest a trip to the agents.
Key fob battery drains
Button is stuck, and or you got some soda spilled in the fob.
Car won't start and the starter is new
Try the 2nd key
Try new key fob battery / 2nd key fob
Check alarm relay
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
