Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother mfc paperfeeding problem
In the middle of printing, the printer suddenly will not accept and feed paper through. Please Help!
Does the fmc240 has a back to stop paper from going out and when the paper comes out without the back, it only blank paper that comes out
Posted on Feb 20, 2008
Brother mfc-7420 printer - manual feed instead of automatic
ok, thank you
you probably had a document that was not using 8.5 x 11 paper or the print settings were the printer to use the manual tray.
thanks adi
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8440 shows "manual feed" and will not feed from tray
go to your cpu in the printer set up and tell the printer what you want it to do
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 5840-CN - line appearing on copies
I have no idea whats happening here.. But it sounds a bit like when he prints from the pc, it uses a different paper stock? Could it be the paper from a direct copy is being used from a different source or tray? Or maybe it's like a 'draft' copy?
I know thats not much help, but if you want, I can spend some time investigatiing this.. But as over a hundred people have never bothered to reply to my posts, I'm a bit reluctant to waste time, unless it's appreciated.. Let me know if you really want to get involved at a deeper level..
May 22, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to print and showing an 'unable to print 5A code
There are diffrent reasons for this error:
check, if something sticks in the machine (paper or metal clip)
The paperfeeder clutch gear is broken: check if the paper feeder works well.
The purge station has problems to do the cleaning jobs: gear broken or too much ink within the purge tubes.
Anyway, this problem is hard to handle for a novice due to so many diffrent reasons.
You should contact a service dealer and in case it is still in warranty let fix them.
Mar 06, 2008 | Brother MultiFunction Center MFC-440CN...
Photo paper jamming.
You didnt tell us what phtopaper you use. Especially the weight of the paper! Brother printers are known to have probs with paper thicker then 220g. The paperfeeder cant feed the paper correctly into print position.
another reason might be that the paper isnt placed well into position. Have a look around the FAQ, too:
http://welcome.solutions.brother.com/bsc/public/as/nz/en/faq/faq_top.htm?reg=as&c=nz&lang=en&prod=mfc440cn_all
BTW: If you print a lot of photos it might be cheaper to do that with a (online) print shop.
Jan 04, 2008 | Brother MultiFunction Center MFC-440CN...
I have a new mfc 440 -- I can not get the paper tray to release it moves 1/4 "
Open the paper jam clear cover on back side of the printer. Now you can push the paperfeeder towards the printer inside. When done try again to pull out the paper tray.
Dec 28, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
May 07, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
120 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
