install nero then then have a try..... as i think the lens has bcame weak... so if are good at opening.. then open the drive with the door ejected and remove the rubber belt connecting the dc motor & clean the lens by using the white petrol or spirit... then fully clean all obstacles inside & refit all including rubber belt then try erasing ... it should work ... if u are not good at opening then take the drive to technician then just have clean ... anyway he will not charge u much for that ...
Comments:
Feb 13, 2008
- Format the partition which have the operating system windows home then install it newly.... before reinstalling just have a try to erase disc wit windows xp itself by entering in to drive it will show the erase option on left column ...
Feb 13, 2008
- if the same problem persists then get the lens cleaned it should work & it will work.... it s not the matter of dirty in that ...
My Gateway Laptop Model #400SD4 cd burner is not working properly. When burning from iTunes after 2...
(More)
My Gateway Laptop Model #400SD4 cd burner is not working properly. When burning from iTunes after 2 songs I get an error message. Although all the songs appear on the cd only the first can be heard. How do I resolve this problem?
