Question about GE GTS20ICNCC / GTS20ICNWW Top Freezer Refrigerator
Fresh food compartment is freezing G.E. mdl# GTS201CNWW
Fresh food compartment thermostatset at <2, fresh food compartment temp is +40f. Vegetables in crisper drawer are frozen.
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
  • 531 Answers
SOURCE: Amana BRF20 - freezing in fresh food drawers
check your door not closing stay (ajar)
Posted on Apr 01, 2009
SOURCE: Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Posted on Aug 10, 2009
omaharox
  • 166 Answers
SOURCE: Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Posted on Jan 20, 2010
Why do my vegetables freeze
Do you have frost buildup on the rear wall of your freezer? What is the model number for your Whirlpool? It is important that you provide the model number so I can see what may be causing the freezing temps in the fresh food section/crisper. Thanks JT
Feb 06, 2013 | Whirlpool Refrigerators
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Have Sub zero side by side 561 Why does the temperature control not increase the cooling of the refrigerator? The milk and vegetables are spoiling.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Refrigerators
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezing in refrigerator
Inside the fresh food compartment on top left there is something called an air baffle. It runs between the freezer and fresh food compartment and its purpose is to electrically control the amount of cold air coming from the freezer. Sometimes they freeze open and will not close. So you may need to turn off the refrigerator during the time you examine it. Look for ice blocking the movement of the baffle damper. Sometimes just one time clearing the problem is all you need to fix it. Let me know what you find and if you are able to get it going again, Thanks, Sea Breeze
May 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
TOO Warm....fresh food
IT SOUNDS LIKE THE AIR DUCT TO THE FRIG. MIGHT BE STARTING TO FREEZE UP,CHECK THIS FIRST ALSO MAKE SURE TEMP THERMOSTAT IS ON INITIAL SETTING,LET ME KNOW-MIKE
Jun 24, 2008 | Amana ATB1836AR Top Freezer Refrigerator
Open Questions:
See all GE GTS20ICNCC / GTS20ICNWW Top Freezer Questions
GE GTS20ICNCC / GTS20ICNWW Top Freezer Refrigerator Logo
59 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
