Question about Evenflo Cozy Carry 5
Help need to move straps can't find manual
I did not have manual either, but if you remove from base and turn infant seat upside down you will see the two straps (right and left) and the metal rectangle peice holding each strap in place. Pull on the straps and turn the metal pieces so they slide through the slats in the plastic of the car seat and that should release them easily.
Posted on May 17, 2008
Need to adjust straps
Posted on Feb 12, 2008
My underwood 3 cord (makes the carraige move ) is broken,, i dont know how to fix it,,like where it should attach pls help!
If the strap or cord actually broke, you have to know what you are doing. The strap attaches to the mainspring which needs the proper tension by how many winds you give it. This can be a bit tricky and even risky if you don't know what you are doing. The strap connects to a pin or ear of sorts on the right underside of the carriage. Hope this helps.
Oct 22, 2013 | Office Equipment & Supplies
REPLACING FUEL TANK STRAPS
I know it can be a bear if the bolts and pins are rusted. Unless the new straps are OEM, some after market straps don't fit quite as well and you need Godzilla strength to manover them into place to get them pinned and bolted back up.
You shouldn't have to drop the tank as long as you do the straps one at a time. Get a floor jack, transmission jack or even a motorcycle jack and place wood under the gas tank and do one strap at a time. I used a second jack to help push the strap in place so I could push it into place on a 97 Dakota. Good luck and sometimes it goes smooth but, some times it makes a preacher say things they wouldn't say in church. :)
Dec 28, 2011 | 1996 Dodge Dakota
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
Carseat straps
You can move it by pushing down on the flexible tab part of the seat base just above the box, but you don't need to move it at all in order to adjust the straps.
In order to move the straps I remove the clip side (the opposite side of the box), this removes in the same manner as the black box side, you just push down onthe flexible tab on the base; and run it through backwards, slide it into the next hole up, to make it larger run it back through the holes and click it back into the base in the back of the seat. This can all be done without disabling, The clip in the front of the seat must be unfastened but it will all fit through the holes in the seat to adjust the straps.
Oct 04, 2007 | Evenflo Embrace - Rainforest
Garage Sale Car Seat
If you push down on the top of the handle you should then be able to move it. Also, to remove the straps you have to feed the bottom portion of the straps from underneath the seat up through first and then you should be able to feed through the material to remove the pad.
Aug 18, 2007 | Evenflo PortAbout 5 Infant
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Jul 31, 2007 | Evenflo Embrace - Rainforest
Evenflo Cozy Carry 5 Logo
194 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Rob Sinbad
Rob Sinbad
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
