Question about Nokia N70 Cellular Phone
Camera hi, i can not get my secondary camera to work it comes on then within seconds it turns off.
  • Anonymous Feb 13, 2008
    I cannot open my phone directory pls help.
  • 13 Answers
Just check your sliding back cover maybe it is a little bit loosen.
Posted on Feb 13, 2008
Peugeot 406 key fob not operating central locking
406 FOB / PLIP PROGRAMMING :
The 406 deadlocking remote control has specific button controls, and if the vehicle has two controls, one is set as primary and the other as secondary.
When replacing the Plip, a Primary or Secondary Plip are different part numbers and must be ordered as required. The white label inside the Plip is labelled PRIM or SEC.
1. Turn the Ignition switch ON.
2. Press the large Plip key button (Primary Plip)
3. Within 10 seconds press the large Plip key button (Secondary Plip)
4. If there is one remote, press the Primary plip button twice.
5. Turn ignition OFF.
6. Test Plip's for correct operation.
NOTE : On some 406 models, Plips cannot be re-synchronised unless the battery has been disconnected for 1 minute
Oct 27, 2012 | Cars & Trucks
Cannot use my secondary camera
Hi there!
For you to use the secondary camera on you mobile phone do these:
-Press/hold the camera button which is on the lower left side of your phone -Once you have the primary camera activated tap/press options and select Use Secondary Camera
Hope this helps, Rate if it worked. Thanks
Apr 13, 2011 | Nokia 5800 XpressMusic Smartphone
COMING ON BUT SWITCHING OFF WITHIN SECONDS EVEN
You may check whether your lens is popped out or not. If your lens is keep popped out then there are chances that your Shuttle is locked inside the camera.
Solution is need to replace the Shuttle, and it may possible that you gently (accidentaly) pushed/press the lens.
Regards Rushi
Feb 18, 2010 | Olympus D-545 Zoom Digital Camera
Camera turns off within seconds batteries are new
Are You Using Regular Or Alkiline?
cameras eat batteries fast. the best cameras have rechargable battery packs.
i'd use energizer or duracell. try to stay away from alkiline rechargables as they wear out fast. try Nickle Medal Hydrate Batteries (NiMH).
Aug 13, 2009 | Nikon Coolpix 5700 Digital Camera
Error message
try Klomtrix trick this worked with my camera thanks klomtrix
Oct 25, 2008 | Panasonic Lumix DMC-LC33 Digital Camera
Epson PhotoPC 3100Z Digital
I would use hi capacity rechargable batteries, perhaps 2700maH batteries, and also check that the battery contacts are clean and grease free
Apr 08, 2008 | Epson PhotoPC 3100Z Digital Camera
Won't turn on
Hi, The camera has automatic in function , if you turn on camera without pressing the camera within few seconds it will shut off automatically, You just press shooter it will on instantly.
Jan 09, 2008 | Sony Cybershot S650 Digital Camera
Nikon Coolpix 775 autos off within 10 seconds
This is either due to one of two problems.
I will start with the simple 1 first.
Go to the menu settings, and select the "S" page, at the bottom is selection for AutoOff, check the settings for this. I would suggest 1 min being about average for most users.
Come out of the menu settings, and leave the camera for 1 min it should auto power down in about that time give or take a few seconds.
If this works then that is the problem solved.
The more complex issue is, that if you camera still is affected by short auto shut downs, then you need to buy a new battery. I paid about £5 for one of ebay, so they are available.
Hope this helps
Matt4666
May 23, 2006 | Nikon Coolpix 775 Digital Camera
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
