Question about Sony KDF-E42A10 42 in. LCD Television
Red, horizontal color bar along bottom of screen
Here's a picture of the problem, it's always there. I put a channel with snow to make it easier to see the red stripe. Just started in the last few days, doesn't matter if I have a DVD input or cable. The stripe is about 1" thick. The rest of the picture looks sharp and bright, so I'm thinking it's not a lamp problem.
Tried to call Sony, they said to unplug the TV 5 minutes and plug it back in to the wall (no power strip). I tried that, had no effect.
Any help would be great!
    Champion:
  • 208 Answers
This is a failure within the optics block. The optics block will have to be replaced. Contact Sony and complain and they will most likely refer you to an auth. service center and I know they will work with you on the cost of repair. I have had experience with Sony paying from 100% to 75% for this repair.
Posted on Feb 22, 2008
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Screen display mode
    Because the broadcaster is giving you the bars at top and bottom there is nothing you can do except use the different aspect or screen formats that are on your TV. Please take a few moments to rate my answer. Thanks....
    Nov 20, 2009 | Televison & Video
    Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
    hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
    in your case i have 2 posibble answers.
    1) negative image
    tv turns on and shots down in 2sec
    flashing pixels on screen
    dark image
    has sound but no video
    screen goes black and then return to normal picture
    vertical color lines on screen no video
    vertical color lines with video
    vertical bars on screen
    horizontal lines on the image
    picture goes red after while
    IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
    2) just left part of screen working
    just right part of the screen is working
    vertical and horizontal lines on screen
    part of screen not working
    some functions not working
    no video but has sound
    functions not working at all
    IT COULD BE (LOGIC CONTROL BOARD)
    TErry HerreRA
    Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
    RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEAR ON THE SCREEN...
    Remove battery , let sit for 2 miniutes . Re install battery , in proper position , hold on button for a few seconds and this should work ...
    Jun 11, 2017 | HTC TYTN GSM Phone
    Red bar across top of screen??
    I had the same horizontal, solid red bar along the top of the tv screen. I have an older analog Philips Magnavox TP2785C221. It just started all of a sudden. It was on every channel. However, the bar did not appear on the other input channels (e.g., AV1, AV2). So this meant that the red bar was only occurring on the antenna input. I unplugged my cable decoder box and restarted it. The red bar went away and that seemed to solve the problem for now.
    Jun 25, 2008 | Philips Magnavox 42MF521D/37 Television
    I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
    Sounds like a convergence promblem.
    Here are some of the most common symptoms of a convergence problem.
    Screen looks 3D
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed in or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence or magic focus section.
    Try to adjust the convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Its a fairly easy fix on the Hitachi sets.
    You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
    Everything you need to fix it yourself.
    Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
    Hitachi 61SDX01B
    The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
    accurate because the red and blue convergence overlays on
    the green.If you have more than an alignment issue,that will need
    repair before adjustments are attempted.
    Emerson tv model no. ewf2704
    Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
    Sep 19, 2007 | Emerson EWF2704 TV
    Sony KDF-E42A10 42 in. LCD Television Logo
    100 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
