Question about Dell Dimension 4600 PC Desktop
No power to my dell dimension 4550
I get no power to my dell 4550. there is no green light when I try to turn it on, the fan doesn't work. if i open up the case then the power if on there is green light on the motherboard
  • 2 more comments
  • klesw Apr 19, 2008
    I have the same problem on a Dell e510...When I plug the computer in, the green light shows up on the mother board. When I push the power button on...absolutely nothing happens...no fans no nothing. I've removed and reseated the memory...checked all connections..removed modem cards, etc. My guess is that the power switch itself has gone bad...or the capacitor on it is shot...does appear to be a mother board or power supply problem..I simply think the power switch is not working and thus is not turning on the computer anymore.
  • abbeyroad17 May 11, 2008
    same problem here, the small green light and a high pitched noise come whenever i put the plug in the power supply, had the power supply tested and it still works, dont get any of the 4 lights in the back, computer doesnt respond at all to anything, only thing i get is the green light on the motherboard.
  • Bearrose Apr 21, 2009
    My Dell 4550 was working fine Saturday and then on Monday it won't power up. There are NO lights on the front on... none at all.
    It's been a lemon from day one. I had to put a new hard drive in it a year ago and I was going to turn it on to install new drivers for a replacement ethernet card when I discovered that it was dead as a door nail.
  • brian c
    brian c May 11, 2010
    Was the unit recently moved around / bumped / dropped?
It might be a couple of things bad powersupply or power button incorrect ram module or hard drive settings ,if not then lastly have a bad motherboard which we all hate. you said you have a a green light on motherboard? Did you upgrade or install any new ram ,harddrives etc check make sure they are seated properly in their sockets and free from dust check connection on the ram module make sure it shinny brass color if not you can use an eraser to clean them. If you have upgraded check make sure the ram is compatible to your machine sometimes the wrong ram install can cause no power up problem. Do you have four green lights in the back of machine? Dell new desktop has 4 green light in back of the unit . if all four light are green then system is ok but one out of the four light are orange then you have a problem. You can go onto dell web sight for your machine to check out these lights codes. I hope this help you out some.
Posted on Feb 12, 2008
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
Dell dimension 4550 will not turn on
Bro change your power supply into a new one, becuase some of that problem occured in your power supply, due to power watts over load of voltages malfunctions.
Jun 16, 2010 | Dell Dimension 4550 PC Desktop
My dell dimension 4550 wont turn on i unhooked the power supply and jumped the pins to get my power suppy fan to come on but i dont know if its putting juice out
At the plugs check the yellow and black (black is ground) and the red and black. You should get 5v on one and 12v on the other. The fan needs to stay jumpered to check for voltage. At the main plug you should also find 3.3v
Dec 14, 2009 | Dell Dimension 4550 power supply ****...
Dell Dimension 4550 will not power on but standby light on.
In all my years of fixing computers, 98% of the time it is the power supply, 2% the motherboard and 0% the switch. Just because the standby light is on does not indicate that the power supply is functioning correctly. The power supply puts out many different voltages....5v, 12v, 1.3v, and 3.3v. If the 3.3 is working then the standby light will come on but if any of the others are not working correctly then the computer won't turn on at all. You can check the switch by checking the resistance of the two wires that the switch are attached to using a multimeter. When the button is depressed, it should go to 0 and when it is not depressed it should be at 1. I would suggest swapping out with a known working power supply to verify the issue.
Jun 25, 2009 | Dell Dimension 4550 PC Desktop
Dimension 4550 CN 02U819 power supply works but
many dells take proprietary power supplies. if you are using an aftermarket power supply, then you may have burned out your mobo. irregardless, your mobo may be dead, and that mey be the very problem.
Jun 08, 2009 | Dell (E210882) Motherboard
Dell dimensio 4550
you need to replace your motherboard. contact vendor
Dec 15, 2008 | Dell Dimension 4550 PC Desktop
PSU
You can try to rearrange from ATX form to dell form.
Here is ATX arangement
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
and here is dells arangement
http://www.jdresearch.com/icon/shark20pin.jpg
Jan 31, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
784 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
