Question about RCA RTD160 System
System tray door won't open
Get some tools and open your CPU. Then un ***** the tray out. Or you can get a butter knife and try to pull the tray out from the two sides. and while your doing that press the open button on your tray at the same time.
Posted on Mar 10, 2008
Why Won"t the sliding door stay open long enough to insert the cd
There is a switch under the carriage that the tray should hit when it opens to stop the motor
Jun 09, 2014 | Audio Players & Recorders
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Isymphony m1 CD tray won't open
The CD door drive belt has broken. The same has just happened to my iSymphony. I'm now trying to source a new belt
Dec 25, 2012 | iSymphony M1 Shelf System
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
CD/DVD door will not open
I have the same problem once in a while usually after a disk read error. If you power off the system (unplug it) it will reset and the door will open.
Jul 13, 2009 | Bose Lifestyle 18 System
Sonycmthpx9
if under warranty, send for repair.
No warranty, open it yourself and try to open the cd tray/door. remove anything stuck between the tray/door or wriggle the tray/door.
Aug 23, 2008 | Sony Audio Players & Recorders
RCA RTD160 System Logo
71 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
