Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
Issue with cd/dvd drive
My cd/dvd drive is not reading ........
can see the light glowing on the drive...
check in the device manager.... the drivers are working fine
deleted upper fillters and lower fillters from registry
still the drive not works
what should be done ...............
    Problem Solver:
Did you try cleaning the drive? Maybe uninstall the driver and then reinstall it.
Posted on Feb 13, 2008
Check my verify code
Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur
Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manage with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers.
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrative tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Oct 06, 2011 | Teac (DV-W58GA-PUK) Burner
My dvd drives can read cd but cannot read dvd disc
that seems strange if it reads cd's it should read dvd's
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 15, 2011 | LG Computers & Internet
Cd not working on my compaq laptop .spins then cuts out
Hello there,
Now what I understand is that, you have the CD seated inside the drive and it starts rotating and then it stop's, Lets try the possible steps to get the issue resolved.
Now another important thing is that, you will need to check with another CD not a DVD to see if that works and based on what you have posted, we kind of come to a conclusion that it might be a problem with the Drive itself, so please check and see if it can read a CD, Once you are done performing the step try using a LENSE cleaner and see if that resolves the issue.
Now once you find that you DVD drive reads CD but not a DVD we can say that the hardware itself has a problem, However if it does not read any of the Disks then there is an issue with the lense and please use a lense cleaner as adviced. If not please check for the step's below to check the drivers.
Now the first thing is to check if the drivers for the device is workinf fine.
Go to my computer, which should be in start or you might have it on you r desktop aswell.
Right click on my computer, go to properties, and then in the hardware tab you will find device manager.
or
The easiest way is to use the run command, That is go to start- run- type- devmgmt.msc and key in ENTER, you should see device manager.
or
Right click on My computer- Click on manage- Then select device manager from the list of options you will see on the LHS( Left hand side).
Now Presuming we have reached Device Manager, The next step to be performed is to check if you have the CD/ DVD drive working effitiently or not, How we can do it is by following the step's below:
Go to Disk drivers on to the right hand side of the window and expand disk drivers and check if it has a yellow or a black exclamatory mark on it, Well if it does,
Go to ACTION and scan for hardware changes, Result will indicate what exactly is the problem.
Most of the time it is never a problem with the drivers for CD/ DVD drive but still no harm in checking for it as a last option.
Jul 13, 2010 | Microsoft Windows? Vista Home Premium...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?┬▒RW DL...
Hello my Dell Studio 1435, it can read CD but not reading DVD... it give noise when i put DVD..
Try using a good quality DVD cleaner first. The lens for cd/dvd are different so one may work if the other is dirty. If cleaning does not work then the dvd lens may be out of alignment or broke. With today's prices it is cheaper to replace the drive $30-40 than try to repair it. Hope this helps.
Sep 11, 2009 | Dell Studio 15 Laptop
Cd/dvd rom LG GSA-T10N doesn't burn or read any dvd
some drives ( multi-Drives ) will read and write CDs but Only read DVDs.
Also check that the Drive supports DVD- Or DVD+ Disks.
Check that there are no yellow Marks In The Device Manager. to Do this:- My Computer/Control Panel/System/Device Manager to ensure all drivers are corectly installed.
mike @ compurepair.
Jun 11, 2009 | ASUS Computers & Internet
MY DVD/CD DRIVER IS NOT READING ANY DISK
Is your DVD/CD Drive appear in My Computer? Can you see it listed? If not, try these:
You may be required to go into the registry to fix this issue, so if you are not too comfortable going into the registry, you might want to get help (but I have written the instructions you can follow)
Check the Device Manager.
Start > Control Panel > Double Click the System icon > Click the Hardware Tab at the top of the box that opens > Click the Device Manager Button.
Click the [+] sign beside the category DVD/CD-ROM Drives
After clicking the [+] sign and the DVD/CD-ROMS Devices category opens up, is there a DVD Drive listed? If there is, when you right-click the DVD Drive and choose properties, does it give any error code, like Error code 39 in the grey box that appears when you choose properties?
Normally the DVD drives use the default Windows drivers. Try right clicking the DVD Drive under the DVD/CD-ROM Drives category in Device Manager and choose uninstall. Then reboot the computer and Windows will find the device and re-install drivers automatically.
If you are still getting the error or the Drives do not show up in My Computer ("poste de travail"), it may be an update or some other program that added data to the DVD's driver data in the registry. Try this:
1) Close all open programs
2) Click on Start, Run, and type "regedit" (without the quotations) and press Enter. Back up (File > Export) the registry before you make any changes)
3) Click on the plus signs [+] next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • Left Click and Highlight: {4D36E965-E325-11CE-BFC1-08002BE10318} **Make sure you choose this exact key**
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand side panel:
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed on the right hand side, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
This should fix the problem, let me know if it worked for you
Apr 25, 2009 | Lenovo 3000 Y410 Notebook
DVD DRIVE/CD-WRITER
GO TO CONTROL PANNEL
SYSTEMS
HARDWARE
DEVICE MANAGER
CLICK DEVICE MANAGER(WINDOW)
EXPAND CD /DVD ROM DRIVES
RIGHT CLICK ON SELECTED DVD/CD DRIVE
SELECT PROPERTIES
1.SELCT DRIVER ( CLICK UPDATE DRIVER)
2.CHECK DVD REGION CODE.
3.UN-INSTALL DRIVER
4. REINSTALL DRIVER AGAIN(AFTER STEP 3)
OR
IN DEVICE MANAGER RIGHT CLIVK DVDCD ROM DRIVE
UN-INSTALL DRIVER
OK
REBOOT COMPUTER
ADD HARDWARE(CONTROL PANNEL)
IT WILL PROPMPT FOR INSTALLATION OF DRIVER
SAY OK.
PROCEED WITH WINDOW INSTRUCTIONS
DVD/CD ROM DRIVER WILL GET INSTALLED AFRESH.
HOPE IT WORKS.
Jul 01, 2008 | Computers & Internet
Dvd combo not reading/writing any CD
since the device can't identify a disc anymore it is adviseable to get another.
Uzowuanya
e-mail: uzowuanya@yahoo.ca
Feb 13, 2008 | Computers & Internet
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
