VCRs
Problem for VCRs
Generic problem for all VCRs
Issue I believe with the Horizontal Synch
By Tim Hunt on Feb 12, 2008
I us a Sony SVO-1420 VCR which is a number of years old as you might guess. I use a Sony DCR-VX2000 camera to feed the signal to the VCR.
Here is what occurred.
I put in a new MAXELL BQ-120 tape and I then put a test on the beginning of the tape and the test then and now plays back without any issue. I then started a recording which while I was monitoring the recording showed a solid picture. I stopped at approximately 1h 40m into the taping and played back what had just been recorded. Upon playback the image was jumping all over the place as though there was no synch.
I switched to a different machine and finished the job with a solid picture.
Upon review of the tape, as the recording progresses initially the top left corner of the image begins to break up. I would call it a "Page Curl" effect (hopefully that makes sense) and then as the recording continues this begins to effect more and more of the image until the image becomes completely unstable.
My Questions are:
1.) What can I do to attempt to salvage the picture.
2.) What do you feel, in your opinion, went on here.
I will tell you that the following day I put in a new tape and recorded it for 2 hours and the unit did not fail.
Another question is that while I have always felt that tape is the best medium to record to from a fail safe standpoint I realize that tape is at some point cease to exist. What medium should I be looking to move to?
Thanks for any help to the above questions.
Solution #1
posted on Feb 12, 2008
Not Rated)
pauldonp
Rank: Guru
Rating: 88%, 1270 votes
Hi this problem sounds like the tape was damaged somehow maybe faulty when you brought it because if you had no problems using a different tape then that rules out the head been damaged inside the video so i would say the tape was faulty.
Also you are right they dont make videos anymore and eventually wont be able to buy blank tapes the best format that you should invest in is a camcorder that takes memory cards these can hold alot more than the tapes can and the quality is 100 times better and less likely to fail on you also you can store everything on your computer and then transfer to dvd.
Let me know if this answered you question or if you need further assistance ok
Comments:
Feb 12, 2008
- Their was possibly a crease in tape or the tape wasnt finished properly during manufactoring process this does happen from time to time this is why knowbody uses this medium any more its just not reliable enough and after viewing a few times the quality get worse and worse with digital disk or data card camcorder the quality is high every time and dvd or vcd can be viewed as much as you like without affecting the quality hope this is telling you what you need to know let me know ok
Popular Solutions for VCRs
Questions and Unsolved Problems for VCRs
Answer
which is better sylvania 6260VE vs funai picachu vcr recorder
Answer
manual for VCR MODEL NV.SJ216B.S SERIAL NOF2A01396 MANUAL REQUIRED
Answer
I can not bring up the function that allows me to switch from TV to CATV.
Answer
can't eject tape out of vcr
Answer
How do I copy a VHS tape onto a mini-DV tape?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top VCRs Experts
Top Audio & Video Equipment Repairmen
in , AR
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
