Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
1998 Jeep Cherokee NO HEAT
I have a 1998 Jeep Cherokee and I have no heat. We replaced the radiator and the thermostat and still no heat. It used to have very good heat within the last couple weeks it started having no heat. Please any suggestions would really help!
  • Dodgechick Feb 12, 2008
    We had the radiator flushed and then it started leaking the heat started going right before we had this done. So we replaced them both and we still have very little heat. One of the water pipes is cooler than the other.
  • 4,102 Answers
Hi if the heater fan is working properly and blowing into the jeep then that rules out the fan being the problem and depending on how the temp switch works it will either be cable switch ie when you turn the dial it pulls cable adjusting the flaps near the heater rad allowing hot air in or blocking it off so it just let cold air in from the outside.
Now if its an electronic switch this could be your problem you can take switch out and clean the contacts
Is the loss of heat the reason you changed the rad and thermstat or has this problem come after you changed the rad and thermstat.
If the problem occured after you fitted rad and thermstat then your problem is 100% blocked air in water system if this is the case then you need to bleed the system getting all the air out.
What you need to look for is plastic screws attached to any water hose dont undo these with engine hot as the pressure will force water out burning whoever is doing it with cool engine undo these and let any air out.
If air isnt the problem then you will need to replace the heater switch one way of checking for air is by touching the water pipes when engine has been running and see if their is any temp differance anyway its worth bleeding the system anyway just to rule this out.
The heater works off seperat rad that is fed by the main rad the heater rad is located towards back of engine towards the bottom you will see two water pipes running into the bulk head these are the feed and return pipes for the heater rad if you get the engine warm enough to open the thermostat for few minutes then touch both of these for temp if it is an air isuue then one will be cooler than the other let me know ok
Posted on Feb 12, 2008
  • paul proctor Feb 12, 2008
    If thats the case and ones coller than the other this usually means one of two problems the first being thermostat but if you replaced this and are sure its working then that wont be the problem the most likely cause is air in the system their should be bleed screws located on some of the pipes also you know the water bottle where you fill up the water is their a thinner pipe that goes into the top of bottle but not into the water im not sure depending on you year if it has this.
    If it does then pull this off the bottle and put it lower than the bottle and see if the water comes out of it listen for air once you have water coming out put it back on or if you dont have this pipe .
    1. Take the water filler cap off and leave off
    2. pump the water by hand by sqeuzing the water pipes squeze the thicker ones towards the bottom of rad press them quick and hard this should pump the air round the engine and out into the filler water tank.
    3. if you watch the filler tank you should see air bubbles coming into the water from the bottom.
    The best thing to do is follow the water pipes and any that have a bend in give these a few good squezes and this should pump the air around and out ok.
    Let me know once you done this then i can assist you further also you can check the thermostat by placing it in boiling water and see if the bellow open allowing water through but well try this after you tried pumping the air through.
    Im offline till morning time here is 23:40 uk time im back on line about 10:30 am uk time so speak then ok
Heater fan 1998 jeep grand cherokee limited no heat very cold. replaced heater core, had system flush. was told fan was missing a blade reason for no heat. does not make sense to me. help. I love my jeep...
First thing I would do is check thermostat you can buy digital temp readers cheap now if you don't have one.aim the temp reader on the thermostat housing once engine is warm should read 190 degrees or so.
Jan 05, 2014 | Jeep 1998 Grand Cherokee Limited 4x4
Heat doesnt work in my jeep cherokee when driving but when sitting heat works
Put a piece of cardboard in front of the radiator. Only if it's cold out though, Usually in really cold weather, the cooling affect of the cold air circulating around the radiator keeps the fluid from getting hot enough to produce heat unless your running in park.
Dec 17, 2013 | 1998 Jeep Grand Cherokee
My 1998 Jeep Grand Cherokee is over heating and I have already replaced the water pump. Someone told me it might be the heat censor. Could this be right and if so how much is it going to cost me.
Be careful, with engine at normal oper. temp. feel both upper and lower radiator hoses, they should both feel the same, warm to hot, if not the same temp. replace the thermostat.Heat sensor either work's or not, if it reads hot, engine is hot, or will not work at all.
Sep 01, 2010 | 1998 Jeep Cherokee
Getting no heat just cold air in my 1994 jeep cherokee XJ. I replaced the thermostat, heater valve and radiator still no heat.
reverse the hoses on the heater core and run water through them to see if the core is blocked if not blocked try changing the radiator cap so you have 16 or 18 pounds of pressure last make sure you have a 50 / 50 mix of antifreeze 50 water 50 antifreeze you should get heat
Apr 09, 2010 | 1994 Jeep Cherokee
1998 Jeep Grand Cherokee Engine Stays Cold
If you have verified that the dash temp gauge is correct by checking temp of coolant in radiator,yes your guess would be what i would change,the engine needs to have a 195degree thermostat in it.195 degrees is what the computer is programed to see as normal running temp.
Dec 07, 2009 | 1996 Jeep Grand Cherokee
1998 cherokee radiator fan constantly cycles on and off
not even close to normal, 1st replace the fan sensor on the engine near the thermostat, then retest.
Apr 02, 2009 | 1998 Jeep Cherokee
NO heat in 1998 Jeep Grand Cherokee
this is the problem then, and a very common one at that, bad news is the dash must come out to replace it.
Jan 27, 2009 | 1998 Jeep Grand Cherokee
1998 jeep grand cherokee cooling problem
Your thermostat is stuck closed. It needs to be changed right away. By the way the operating temp on that motor is 160 degrees so you are running hot you have just been lucky so far. Good Luck
Dec 01, 2008 | 1998 Jeep Grand Cherokee
1999 jeep wrangler very little heat
next time you go up a hill see if the heat is still blowing
Nov 30, 2008 | 1998 Jeep Wrangler
2000 Cherokee not warm
Aside from flushing the radiator and heater core andreplacing your hoses, did you happen to replace your thermostat. Sounds to me like that's your problem if everything else seems to be in order. If you change the thermostat and still have no heat, you might check your vacuum lines running to the back of your heater controls inside your dash. That's really the only other thing that I believe could be causing your lack of heat.
Hope this helps! Have a great day and try to stay warm!
Nov 19, 2008 | 2000 Jeep Grand Cherokee
Car Audio & Video Logo
5,879 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
