Question about Visioneer OneTouch 8100 Flatbed Scanner
8100 Visioner conflicts with Vista
I worked with the scanner 8100 Visioner One Touch using Windows XP. When I bought a new computer with Windows Vista I couldn't install this scanner. What is your advice?
  • 1 more comment
  • Anonymous Apr 13, 2008
    I have the exact same problem.
  • edenwrites Feb 09, 2009
    Link to the download does not work..........where else can it be found.
  • Anonymous May 06, 2009
    The links on the Visioneer official page don't work. I have the same problem. My Visioneer One Touch 8100 Scanner does not work on Windows Vista 32-bit and I want to upgrade the drivers to Visioneer OneTouch 9420, but it seems that nobody has working links for this driver download. HELP!
Verified to work with Vista Home Premium x64 (should work for x32 as well):
1. Make sure your 8100 is unplugged.
2. Go to Visioneer's website and download drivers for the OneTouch 9420 scanner:
http://support.visioneer.com/products/home/9420/downloads_1.asp
3. Install the drivers. Nothing will work... yet, don't worry.
4. Now plug in your 8100. You'll get a message saying that Vista wants to find drivers. Select "Ask Me Later" or just cancel.
5. Next, open up Control Panel and then Device Manager. Find your 8100 in there (probably listed as "Unknown Device") and then right click on it and say "Update Driver Software". Now click "Browse My Computer For Driver Software" then "Let Me Pick From A List Of Device Drivers On My Computer".
6. Scroll down to "IMAGING DEVICES" then find Visioneer, then you should see the "Visioneer 9420" driver. Select it. You'll get a warning from Vista, but continue anyways. That's it... everything should work.
Posted on Mar 05, 2008
    New Friend:
I just wanted to add that I've been trying to get my Visioneer 8100 One-Touch scanner (that I purchased well over 12yrs back) to work with new OS of Win10 64-bit. The above instructions for installing the 9420 driver worked for me. This was the 6th or 7th thing I'd tried and was gonna be the last. I was so frustrated after doing every poss thing in my power- to no avail. I tried this as a last resort and to my surprize- it worked. Thank u VERY, VERY kindly.
Posted on Jul 28, 2016
The same solution of using the visioneer 9420 one touch scanner works with a 32 bit processor. Visioneer has both the 32 and 64 bit downloads on its web site.
Posted on Nov 07, 2008
  • gorrou Nov 07, 2008
    Correction: I should have said that the same solution of using the visioneer 9420 scanner DRIVER works to drive the 8100 scanner on a 32 bit vista system.
Install PaperPort as usual.
Open the Vista Program Compatability Wizard. Install the 8100 driver using the Wizard. I chose the XP Service Pack 2 emulation. Works just fine.
Posted on Sep 20, 2009
SOURCE:
One Touch 8100 flatbed scanner will not work on Windows Vista
log onto the manufacture website and down load the vista driver for your scanner
Oct 11, 2010 | Visioneer OneTouch 8100 Flatbed Scanner
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
Microtek Scanmaker 4800 does not work on Vista no drivers all xp. How can you get scanner working?
I really you cannot use this Scanner for Vista, only before Vista came out there's no Driver Freeware available yet or the Microtek didn't not provide the driver freeware for this.
I suggest you to install it with Windows XP, it's better on Windows XP and don't need to install in Windows Vista, it's no use on it.
Or also you just buy a new one ready for Windows Vista scanner.
Provided that the Microtek didn't yet give a driver for this then install it where it is compatible with.
Sep 18, 2009 | Microtek ScanMaker 4800 Flatbed Scanner
I need driver for visioner fu661g 4800u
Same scanner as a Visioneer 4800 usb.
http://support.visioneer.com/products/home/EOL/4800/default.asp
Aug 02, 2009 | Visioneer Office Equipment & Supplies
Dell inspiron 8100 drivers
your audio driver is not helpful for sound card which is you install on your pc.
plaese change this driver.
all windows have different driver for different devices.
so you install the driver compatible with window vista and sound card.
Apr 09, 2009 | Dell Inspiron 8100 Notebook
Lost installation cd for visioneer 7600 scanner usb one touch
Hi! I have the correct driver for the Visioner 5300 / 7600 that will work with Windows XP and Vista. I can provide you a copy with complete instructions for installation. Please e-mail me at: [email protected]. Subj: 7600 driver.
Oct 14, 2008 | Visioneer One Touch 7600 USB
Scanner
After downloading the visioneer 9420 driver file (found on the visioneer site, but before installing it, remove your old 8100 driver, then install the 9420 driver by running the .exe file you downloaded from visioneer. Then, use Device Manager, go to -update device drivers and in the listing you should see the 8100 listed. Double click on it, click on -update, go to -browse my computer for driver software, then go to -let me pick from a list, then you should see the 8100 scanner appear, click on it, click on next, and then it will install the 9420 driver. My 8100 is working great on a vista system. Don't get rid of that scanner! It works!
Jun 08, 2008 | Visioneer OneTouch 8100 Flatbed Scanner
I have a Memorex U48 Flat Bed Scanner and have bought a new compouter with Vista. I need a driver download to work with Windows Vista. Thanks [email protected]
get the winXP driver MEMu1.50 (still available), there are no Vista drivers. Run the installation using WinXP emulation in Vista. You must run the installation as if you are in XP, not necessary when using the scanner subsequently. Now the Memorex 48u works on a Dell Dimension, running Windows Vista Home Premium. Hope this helps. I got the scannner for $14 after rebates at Staples years ago, it won't die.
May 05, 2008 | Memorex MEM48U Flatbed Scanner
I have a 9320 One Touch Scanner and can not find the drivers for Vista. This is creating much frustration as I had purchased the scanner new and can not use it. If possible please point me on where to...
System Requirements PC Microsoft Windows 98 SE, 2000 Professional, ME, XP:
Pentium Equivalent Processor or Higher
64MB of RAM (128 MB Recommended for Windows XP)
200 MB of Available Hard Disk Space
CD-ROM Drive
USB Port
Color Monitor
I do believe the scanner does not support windows vista as of yet.
Printer / Scanner
HP Deskjet 6940 (via Network, auto driver) (32-bit)
HP Laserjet 5L (32bit)
hp color LaserJet 2550L (32-bit)
HP Officejet 4200 (32-bit)
HP PSC 1401 All-In-One Printer (32-bit)
Lexmark 240N (Native Driver x64).
Microtek Scanmaker 3600 (32-bit)
Samsung ML-2010 monochrome laser printer (32-bit)
Epson R220 (32 bit)
Brother HL 1030 works after adding a printer manualy and installing as a brother 1430 (32bit)
Dell Photo AIO Printer 964 (32-bit)
HP Laserjet 4plus (32bit)(64bit) with HP Jet Direct as LPR on Standard TCPIP Port
HP DeskJet 845c (32 bit)
(supported printers/scanners)
Apr 20, 2008 | Office Equipment & Supplies
Scanner doesn't work with Windows Vista
Unfortunately this scanner is at end of life and I do not think you will find any drivers for Vista.
Feb 12, 2008 | Visioneer OneTouch 8100 Flatbed Scanner
Visioneer OneTouch 8100 Flatbed Scanner Logo
2,239 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
