Question about Baby Gear
1998 Jeep Cherokee NO HEAT
We have replaced the radiator and the thermostat and still blows cold air. It will get a little warm when you just sit, but not a lot! when you start to go all cold air. Any suggestions on this problem?
  • 4 more comments
  • Dodgechick Feb 12, 2008
    It is just a plain cherokee.
  • Dodgechick Feb 13, 2008
    One is colder than the other.
  • jeep664 Dec 08, 2008
    I have the grand cherokee laredo model and have no heat! if you let it sit I will get a little heat nothing to speak of though but as soon as you start moving I have even less... the tempature gauge hardly ever moves and when it does its a about a needles width that it moves... Help me please!
  • brian c
    brian c May 11, 2010
    Ok. Let me know the result of the hose test when you get a chance.
  • brian c
    Also, is this a Grand Cherokee? If so, is it a Laredo, or Limited?
  • brian c
    Check the 2 hoses going to the heater core. Run the engine up to operating temperature. Feel both hoses. Let me know if they are both hot.
  • 50 Answers
Yes you have a air lock you need to run the car with the rad cap off till the air bubbles out
Posted on Feb 13, 2008
Heat doesnt work in my jeep cherokee when driving but when sitting heat works
Put a piece of cardboard in front of the radiator. Only if it's cold out though, Usually in really cold weather, the cooling affect of the cold air circulating around the radiator keeps the fluid from getting hot enough to produce heat unless your running in park.
Dec 17, 2013 | 1998 Jeep Grand Cherokee
98 grand cherokee little heat.heater hoses hot top rad warm bottom is cold collant barely luke warm
While it doesn't seem likely, if you've changed, or had the thermostat changed.... I'd say you got a faulty thermostat. I am curious as to what your temperature gauge says the temperature of the engine and coolant is.. If your gauge is showing hot, I can think of two more possibilities... the water pump isn't pumping right... and, if the water pump isn't working right, the problem can be a cracked head or block, which can cause an airlock in the coolant system. Check the coolant or radiator cap.
Nov 14, 2013 | 1998 Jeep Grand Cherokee
1999 jeep grand cherokee overheating...
You need to fill your antifreeze with the truck running and your heat on. You leave off the radiator cap and let the truck warm up. The cap is left off to bleed air out of the system. Once the truck reaches temp for the thermostat to open, your fluid level should drop about 3/4 gallon. Give that a try and see what happens.
Feb 04, 2012 | Cars & Trucks
I have a 2000 Grand Jeep Cherokee Laredo (6cyl). It was blowing only cold/luke warm air. I replaced the thermostat. Still blowing the same only now the radiator cap is cold but hoses are hot. ...
It is likely you have air in the system. Park on an incline, take the radiator cap off, start the car, let it warm up until the thermostat opens, fill the radiator until it stops going down. See if that doesn't get you some hot air. If not, try the other steps I have in my post at http://www.fixya.com/cars/r6235876-no_heat_fan_blowing_cold_air . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me.
Dec 13, 2010 | 2000 Jeep Grand Cherokee
99 jeep cherokee not getting any heat. New waterpump and thermostat. System flushed and has flow. Heater hoses and upper radiator hose hot, lower hose warm. Any way to bleed air out of the system?
With engine cold, remove radiator cap, start engine, if there is air in the coolant system it will "burp" it out through the open radiator cap. Check fluid level and replace cap.
Good luck
Jan 31, 2010 | Jeep 10 x 20
I have a 1998 Dodge Durango SLT-V6 that has no heat.
The heater core might need back flushed, I just did mine this winter. Go to dakota-durango.com and introduce your self and your rare as ever truck, a v6 durango, and have fun.
Dec 21, 2009 | 1998 Dodge Durango
'95 Jeep GCL Heater blows cold air
check vent functions to make sure in heat position vents are fully closed. turn temp switch back and fourth so hear movement of heat vents gl
Aug 29, 2009 | 1998 Jeep Cherokee
1999 jeep wrangler very little heat
next time you go up a hill see if the heat is still blowing
Nov 30, 2008 | 1998 Jeep Wrangler
Heater only blows warm air.
The hoses from your heater core should be very hot to the touch. Check the hoses going to the core from the water pump. It should be very hot. The return hose should also be very hot. Now check the hoses going to the core. If they are not the same temp, then your heater control valve is not working correctly or the vacuum is not working. At any rate, locate the vacuum line going to the heater valve. Remove the silver bar on the valve from the plastic plunger arm. You will have heat all the time now if it was only a vacuum problem. You can fix it later when it's warmer out. BTW a 200* thermostat will make your heater even hotter.
Nov 21, 2008 | 1998 Jeep Cherokee
Baby Gear Logo
391 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
