Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
PRINTING PROBLEMS THE PAGE IS ALL DARK BUT WE CAN SEE THE PRINTING.
  • 168 Answers
Have you tried a New Drum Cartridge?
It sounds like the drum cartridge is bad. Do you know how old the drum cartridge is or how many copies are on it?
If you take the drum cartridge out (Do not tip this upside down or touch the drum) you should be able to see a shiny long cylinder called the drum underneat the unit. Does it look like its covered with toner?
If it is covered with toner, then the cartridge needs to be replaced and that will take care of your problem with the dark copies.
If its not covered, then it could be a dirty optics which would require for your machine to be serviced. But 99 out of 100 times its the drum cartridge.
Hope this helps.
good luck.
mac
Posted on Feb 12, 2008
Printing with horizontal dark lines
Did the dark lines start after the change? If so, maybe the drum on one of the cartridges is damaged. (Since you mentioned dark, I'd suspect the black cartridge.) Try replacing cartridges.
If that doesn't fix it, you can send it in for repair if it's under warranty. If it's outside warranty, I'd probably just replace it, unless you want to learn a lot about the innards of a laser printer.
Apr 21, 2015 | Dell 3110cn Laser Printer
Printing too light
For understand the issue, little bit technical knowledge required: Take half test page, check how much dark image formed on paper, check on cartridge drum how much dark image created?..(half test page: while printing half of the page switch off the printer, take cartridge out as well as take half printed page)If half page print quality is good on paper: Fuser faulty(teflon sleeve)If half test page print not good & image on drum is OK: Fault with Transfer roller or its bios voltage contacts..If there is proper image on paper & image drum: Problem with laser scanner assembly..find the problem, then remedy is easy..
Feb 02, 2012 | HP LaserJet 3030 All-In-One Printer
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Printing
if your problem is printer setup page in go
and select to the b & w print and ink setting
are dark print set and give your print page
problem is also
Sep 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Hp photosmart 7400
I have solved both problems and it will cost you $9.99 for me to tell you how I solved each problem.
Sep 28, 2008 | Office Equipment & Supplies
Dark mark at the edge of the page from top to bottom when printing
sometimes dirty carona, clean with blue tab on drum, if not then usally it is the drum worn out(expected life 20 000 prints) or less often it is the fuser roller stuffed
Jan 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
103 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
