Question about Jensen Audio Players & Recorders
JENSEN "CRADLE" JCKFM1 MODEL 136D3471
POWER TO THE "CRADLE" BUT NOT THRU AND TOO THE RECEIVER. DO YOU HAVE NEW ONES? PRINTED CIRCUT BOARD?
THANKS
GARY
5 Suggested Answers
messstat
  • 365 Answers
SOURCE: lost my keys cant get new ones how do i get new
google "Mike's Bikes"...believe he's in NC
Posted on Jun 14, 2009
chipsandnuts
  • 70 Answers
SOURCE: Power button dead on remote - Need a new one or replacement
you can purchase a new one at www.samsungparts.com or you can order here 1-800-627-4368
Posted on Jun 30, 2009
  • 98 Answers
SOURCE: Hi! my OMT CD Wurlitzer is in need of a new
I can probably help you. I repair all of the internal circuit boards inside the Wurlitzer jukebox....Which one do you need? Please email Rod Stebelton, tech@wurlitzer-ohio.com.
Posted on Dec 24, 2009
  • 6702 Answers
SOURCE: Why is my Jensen SPX-17 home entertainment subwoofer only putting out about 10% functioning base power volume level and loudness?
Gary, If you have the subwoofer open, what did you keep from measuring the voltage of both power supplies? And while measuring, why not put a load on both, and see what current they can handle?
When the error moves with one component (power supply) the error must be there. Without a multimeter, (I have several, but I'm not close to the power supplies) you can't tell if the power supply is working to full performance. So start there.
Just try to find out, if a part of the rectifier is defect (one diode) It won't be possible to point out what is wrong, if you can't measure on the device yourself.
Sorry.
Posted on Nov 23, 2014
Sorry.
Nov 23, 2014 | Audio Players & Recorders
10 blinks on power light
You need to replace the blown capacitors on your PSB-power supply board. A soldering kit w/flux from harbor freight or radio shack and and about a dozen new Thru-hole caps about 2V higher than the ones your are pulling out.. Or if that isn't to your liking you can just buy a refurbed board on ebay shopjmmy or partsstore. You will need to remove the back panel and pull out the PSB disconnect a few wire harness and some ribbon cables and a few screws the board will pop right out. The board with be printed and say Power Supply with the REV number (part number) printed on it. That's the one you need to look for. If you want to replace the caps yourself you'll visibly see the blown caps they should be completely flat (X) top view no puffs or bulges. It's pretty simple to remove them and solder some new ones in.
Feb 12, 2014 | Panasonic TCP50VT25 50 in HDTVReady Plasma...
Power supply from My Toshiba 32A3000P is defect. The voltages and currents are not provided so therefore the TV is notswitching on. I need the P/N of power supply in order to buy it. Can you support me?
Hi
To buy a new power switching regulator board, you needn't have the part number of it. It can be purchased from Toshiba Authorised Service center by informing the exact model number of your Toshiba TV. They will give you the orginal replacement board. The identification number will be printed on the circut board itsef. You can also buy it from "Alibaba" or "Ebay" by quating that PCB number. Get into their web sites and search for your board. They will send it to you by E-payment. OK.
Jul 15, 2011 | Toshiba REGZA 32A3000P 32 in. LCD TV
This Magellan does not list a model #. It was received as a gift 2 years ago. The printed circut board is broken where the poer cords connects to the unit. Is it worth repair and how much would it...
you need to figure out the model number...if its one like the one pictured in your question, then yes it can be repaired if the circut board itself isnt damaged...the ports are available on ebay for about twelve dollars.
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Sep 27, 2010 | Magellan RoadMate 3000T GPS Receiver
Hi! my OMT CD Wurlitzer is in need of a new printed circut board, is has the phillips CD Player unit CDM12 ABOVE IT. Type;CDF 91 0055647 Model: OMT CD -100 nz NR 41018750 V 100-240 any help with locating a...
Hi Ken,
I would search on Ebay (do a world wide search)
Here is a seller selling the head only.
Item number 380005560333 (UK seller)
There are a number of sellers world wide including Hong Kong and the USA.
Best of luck.
Regards
Alan Hood
ami-man
UK
Item number: 380005560333 Item location: Kingston, Surrey, United Kingdom
Oct 15, 2009 | Wurlitzer Jukebox 1015 One More Time...
Magellan Roadmate 760
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
Turns off when I move it slightly
it must be in the wire...............
get a new cable(power) and try that!
May 12, 2008 | Magellan Roadmate 760 GPS Receiver
Intermitant powering up
Yes, it is most likely the cradle. My unit did the same thing. Picked up a new cradle and it works.
Apr 07, 2008 | Magellan RoadMate 700 GPS Receiver
Dell power Supply has won't work
Hi, all power supply's have a fuse in them, remove the power supply, open it up and study the printed circut board, you will see either a white ceramic or glass fuse attached to it. Replace this and reasemble it then re-install it into your computer and then test it. If you still have no power then you will have to replace the unit as the costs of repair are far greater than a new one. Goodluck, mistyman
Aug 30, 2007 | Dell POWER SUPPLY PS-5201-5D (PS52015D)...
Open Questions:
241 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
