Question about Motorola Mobility RAZR V3
Bluetooth link busy
My phone says "bluetooth link busy" no matter what I try to do - I saw the suggestion where it said to "flash" the phone, but I don't know what that menas.
  • Ninegate Feb 14, 2008
    Thanks for the solution, but I probably should've stated it better - it won't turn on and off....when I try to turn it off, it says that it turns off - but then when I go back to the prior screen, it says the power is still on.
    This is an unlocked phone a friend of mine purchased off the internet, and I saw where someone stated this was a software problem - that during the unlocking process, the correct version wasn't put on the phone.
    I was trying to find a better solution than sending it back, because she already had to send it back for another problem.
  • Anonymous Apr 02, 2008
    blue tooth link busy can't connect
  • 51 Answers
Switch you bluetooth on and then off again.
That Might Work.
Regards,
Sophie x
Posted on Feb 14, 2008
How to link my blue tooth
Pairing the Plantronics Explorer 220:
For most phones, select Settings/Tools, Connections, Bluetooth, On. See your phone's user guide for more information.
With the 220 headset powered off, turn on the headset by pressing and holding the call control button for approximately 5 seconds until the LED flashes red & blue. The Explorer 220 headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again and hold for 5-6 seconds until you see the red & blue flash.
From your phone, go to the Bluetooth menu and select "Search" or "Add Device". Your phone should find the headset which will appear as "2xxPlantronics" in your list of devices.
If prompted for the Passkey (PIN code), enter 0000. If your phone asks for a PIN/passkey, enter 0000 (4 zeros). Pairing is successful when the LED on your headset flashes blue. Your headset is now connected and ready to use.
Here is the link below for step by step instructions.
http://www.headsetsdirect.com/plantronics-explorer-220-bluetooth-pairing-instructions
Good luck from Headset Direct - 800-914-7996.
Aug 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth Expert cant get the 2007 Jaguar S-type Bluetooth workin
Is your bluetooth in Jaguar discoverable to devices?
I would suggest the Jaguar may not be transmitting a signal - In the 2007 Model X Type - There is a specific code ##3#*# Followed by Call button - Which then changes from Phone to SIG *****
Have you tried the above? The Quickguide Jaguar Manual does offer the code specific to Make of Car - It is near the last page of the book.
Jun 09, 2009 | 2007 Jaguar S-Type 3.0 Sedan
2007 Jag S-Type and I work with Bluetooth "No Phone" Error
This means you have no wiring set up.
To find out if your car was prewired, go to the Jaguar website and email them your VIN number and your request for info, they will look it up and email you back within about a day or two and tell you if the car was prewired for the bluetooth.
If it was, you can get the bluetooth up (very expensive) and if not prewired, I am afraid you are TOTALLY out of luck with your current car.
The manual does not discuss th "no phone" message that is only covered in the Bluetooth manual.
Does not matter if it is touchscreen or not.
Jun 09, 2009 | 2005 Jaguar S-Type
Bluetooth link busy
Try it with another BT and see if still shows the same.....if it does, then you might need to reset your phone....refer to user manual on how to reset phone. And if it worked fine with another BT device, then you might want to exchange/repair the jawbone....try this first, drain the battery completely from the jawbone, then recharge it and try to connect after charging..
Best of luck....
Jul 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
BLUETOOTH WILL NOT CONNECT
its possible its your friends phone, make sure your bluetooth is completely on by going to "turn on blutooth" first then make your phoen discoverabel and try it with soemone elses phone. it doesnt matter that it flashes, as liong as it as the lil blue tooth sign on the top of the screen, only problem with that phoen is its supports limited files throguh bluetooth Bluetooth Supported Profiles: HSP, HFP, DUN
version 1.1 / DUN profile carrier-dependent
May 30, 2008 | Motorola Mobility V710
Bluetooth problem
You must power cycle your phone and shut off the device you are trying to pair and start over.
Mar 07, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Bluetooth stopped working
have you tried turning off your phone and removing the batteries? Then try to see if the bluetooth works correctly again.
If all else fails, you might need your phone reflashed or reformatted...
Dec 09, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Samsung wep 150
I think i know why your bluetooth goes red then green. It is because your using a wrong charger like different make of the the charger or is it you never use it for a long time so is completely dead and you have to buy a new charger or bluetooth.
Nov 12, 2007 | Samsung WEP-150 Wireless Headset
Bluetooth link busy
how can i get my h700 bluetooth to stop saying bluetooth link busy ?
Nov 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
707 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
