Question about IBM RSA II ADAPTER (59P299802USA)
Live configuration of RSA II cards.
I've got a handfull of IBM xSeries 366 servers which have RSA capability but the rsa board was not setup when the servers were commissioned. I want to start using RSA on these servers but these are production servers and I cannot shut them down. I tried plugging the RSA boards to my network to see if it would pick up a DHCP address but there is no activity whatsoever. It seems like the RSA card are disabled. How can I reanable the cards to configure them without taking down my servers?
4 Suggested Answers
SOURCE: Unable to setup my raid on a IBM XSeries 346
http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?lndocid=MIGR-55041&brandind=5000008
Posted on Mar 20, 2010
  • 251 Answers
SOURCE: I have IBM xSeries 225
please restart the system once again let us know.
Posted on Dec 13, 2010
  • 181 Answers
SOURCE: Are RSA (remote supervisor adapter) built-in on IBM x3500 M3
Add RSA II card for better performance
Posted on Apr 06, 2012
Usb RSA securID when plug into the usb port, windows 7 says "finding drivers and then errors out with "Unable to find smart card driver"
This pop up only occurs with older versions of the RSA software. Customers should download the latest version of RSA Authentication Client from RSA.com. bres can obtain the SD800 smart card driver -- which is Windows 7 certified -- directly from RSA, but it is not available through Windows Update.
The SecurID "token" from RSA, the security division of EMC, is a two-factor strong authentication mechanism (something you know, plus something you hold). In tandem with a RSA authentication server, a SecurID is used to ID trusted users for firewalls and other restricted networked applications. (It is not itself a firewall.)
RSA's SD800 is a hybrid hand-held authenticator. The SD800 displays a series of one-time passwords, which change every 60 seconds, on a small LCD, but it also has a USB plug that allows it to directly connect to an accessible USB port to offer the full functionality of a smartcard. These include an automated SecurID exchange, cert-based authentication, an array of classic PKI crypto functions, and supplementary key and credential storage.
These are complex services, and they require a sophisticated setup.
The SD800 is intended for Enterprise rather than consumer use. Since the driver must be properly configured by an Enterprise to work in its environment, the SD800 is designed to be installed manually or pushed out by an Enterprise using SMS (along with its complementary GPOs, group policy objects).
The quick solution here is for an Enterprise admin to go back to the vendor, RSA, for the right stuff.
_Vin
Jan 12, 2011 | RSA Security RSA SecurID Appliance...
Steps to configure raid 5 on ibm xseries 232
hi,
which material have you ? : CD
which server ? xseries xxx model type ?
If this is the unique SCSI adapter in your system
or the unique seen, you must:
0) download
90p2772.iso 505,085,952 IBM ServeRAID support CD v6.10
or use what you have.
1) Boot from cd (linux) to configure RAID , before install W2K Server
2) run 23k4684.exe (previous site) in another pc and make a floppy
3) boot from W2k CD and press F6 when proposed
4) insert floppy previously made
5) when OS is installed, or from CD or using 23k4687.exe,
install "IBM ServeRAID Manager", to see activity.
Oct 28, 2010 | IBM eserver xSeries 232 8668
X306m (8849)
Most computers have a bios you access (I see you know how to get there on yours) which allows you to choose options. Being as your bios sees the new card you should be able to either select it as default, or you should be able to click (or unclick) the onboard somewhere. This model looks to be a server, so there are several pages you might have to look through to find it. My server is a HP and it takes forever to makes changes like you are trying to do. Your video card is a 16meg, which should be fine for a server. Most often you don't use a monitor on a server anyhow, they are accessed remotely. But if you still want to change the video card, the following link gives you basic information: https://www-01.ibm.com/common/ssi/cgi-bin/ssialias?infotype=AN&subtype=CA&htmlfid=872/ENUSAG05-0436&appname=USN
Feb 10, 2018 | IBM eServer xSeries 306m 8849 (8849E5U)
Steps to configure raid10 on xseries 346 with 4 HD using raid manager cd
See page 60 of the Configuration manual for that model located at http://www.abchost.cz/download/262-4/installation-guide-serveru-ibm-xseries-346-2u-s-cpu-intel-xeon.pdf
Jan 06, 2010 | IBM xSeries 346 Server
Batteries in keyfob are dead got new ones,how do you reset for a citreon saxo
From what I understand of the RSA Secure log on is that when the unit goes "dead", the connection to the server is lost. In order to restore the connection you will have to call a Helpdesk and have them refresh the server to "find" your keyfob.
Dec 08, 2009 | RSA Security RSA SecurID Keyfobs Full...
How to change bios settings, i.e model/type serial number, enable.disable memory banks
Boot the system
Press F1 to enter the Configuration/Setup Utility
Oct 06, 2009 | IBM xSeries 366 Server
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
How do i get a IBM Xseries server to recognize a serverraid card
IBM Serverguide will most likely get you going again. Go this link:
http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?lndocid=SERV-GUIDE&brandind=5000008. You can download the ISO image for the version of Serverguide that will let you configure your system. If you have a Xseries 360 version 7.2.03 should work.
I hope this helps. Good luck!
-jodair
Apr 03, 2009 | IBM eserver xSeries 360 8686
Computers & Internet Logo
707 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
