Question about Adobe Photoshop 7.0 for PC
Missing some software
When i downloadewd this program it worked ok then i would not it said that some software was missing can you fix it
  • 66 Answers
Well it must have gone corrupt try reinstalling the software or go for software update
Posted on Feb 13, 2008
Use to work but now I get message: "This program can't start because mingwm 10.dll is missing from your computer. Try reinstalling the program to fix this problem.
Uninstall.
Run Ccleaner to clean up the registry.
Reinstall.
Windows does not properly uninstall this program, and the trash left behind poisons the re-installation.
Mar 13, 2016 | Computers & Internet
SKU111.CAB MISSING
This is on the Office Professional 2003 (Retail) disc.
See Microsoft's knowledge base article.
When you try to start Microsoft Office 2003 program for the first time you...
Feb 09, 2014 | Microsoft Office Outlook 2003 for PC
Reinstalled canoscan LIDE 200 on pc after we did a format its a Twain everything works except the toolbox when i try to scan a pdf says something about changing it to Twain we have uninstalled and...
Twain is the scanner interface program on the computer. Something is missing from the install or the XP system software. Double check to make sure you're installing an XP-compatible version of the scanner software. The program for newer versions of Windows likely assumes the presence of some software components that may not be there in XP unless the install program puts them in. Without those missing pieces, Twain won't load properly.
Aug 28, 2017 | Canon Computers & Internet
When i want to try open an image file then system is showing hpqcutill.dill is missing
It seems that your HP Photo smart Essential software is not working properly, you can solve the issue by two methods,
1. Copy all the files in "C:\Program Files\Common Files\HP\Digital Imaging\bin" to "C:\Program Files\HP\Digital Imaging\bin".
2. Reinstall your scanner software if you have the CD/DVD, you can also download latest software from HP website,
For images which are not being opened directly in Windows Picture and Fax Viewer . simply right click any image file and select open with >Choose Program a box will be opened you can select Windows Picture and Fax viewer it will be shown under the recommended programmes, dont forget to check the "Always use this program to open this kind of file" and click OK
It should fix your problem now
If you need any more assistance feel free to reply to this post
Regards,
Bilal
Jan 12, 2011 | Computers & Internet
How to fix a frozen screne
The cause of the freezing, or locking up, of your computer, is due to some either corrupted or missing files. And more specifically, missing or corrupted registry files. These are the files which tell everything on your how it is suppose to work. Basically, they are configuration files. And if these files get corrupted, or messed up, it can wreck havoc.
Sometimes the registry files end up missing. This can happen when you uninstall software from your computer. The software being uninstalled may remove registry files also associated with another program. There should be a message asking you whether or not you want to delete the files as they are associated with another program. Your best bet is to say NO to this and leave the files. If the files end up missing, then the program which needs them will stall, hang, or freeze the next time it tries to run. But there is a simple way to fix this.
By just running registry scan software on your computer, you can find these problems and fix them right away. It will let you know which files are bad, and will fix them to its original state. And it is this simple step which will show you how to fix your computer freezing.
Dec 14, 2010 | Computers & Internet
Freezing frequently ?
Dec 13, 2010 | Dell Inspiron 560 PC Desktop
Start up and desktop icons missing
This could happen due to various reasons like :
1. Any recent update done.
2) Virus infected
3) Windows missing/corrupted files.
There are several steps to resolve the issue.
Try one after another and check if that fixes the issue.
Step 1
Try this Fix
Click on the Download link and install the Fix No. 195 ( Restore Desktop Icons and Taskbar )
Download Link
Step 2
Press CTRL-ALT-DEL to bring Task Manager.
Click on New Task and type appwiz.cpl and click OK
This will re-run add/remove programs.
Remove/Uninstall all new program you installed before having this problem, Also remove the Windows XP Hotfix
Restart your PC.
The access to the taskbar , icons will all come back and Install a new Antivirus.
Step 3
If None of the above steps work, try a System Restore to previous date
Click START - All Programs - ACCSESSORIES - System Tool - System Restore
Choose the date before the system started giving trouble. ( The Date will be in bold ( highlighted ) which indicates the system can be restored to that date with all the settings on that date )
*Note : Doing system restore will uninstall any software/program you have installed from the date you choose the system restore till current date, However it will not delete any files created )
Hope this is helpful.
Nov 10, 2010 | Dell Dimension 9200 PC Desktop
Plugged in web cam and it is saying no video capture capture device
Did you install the software for the camera?
Was the installation successful?
Did the camera ever work before?
You need to explain in more detail this failure.
The main reason why a device fails to work after having worked in the past is a corrupt driver file. Follow these steps to try to fix this problem:
1) Go to the Control Panel->Device Manager window and select your camera from the listed devices on the right hand pane.
2) Right click your mouse and on the ensuing menu select Uninstall.
3) Reboot your machine.
If the driver files are Ok, the next time Windows starts it will detect your camera and will install the driver. Should it fail to install it, it's because the file is either corrupt or missing.
4) Go to Control Panel and select Add/Remove Programs (XP) or Programs->Uninstall Program (Vista) and select your camera software installation. Upon removal...
5) Reboot your machine.
6) Load the disk that came with your camera and try installing the software from this source, as though it's the first time you're doing it.
If the installation goes without a hitch, then your camera software will run prompting you for certain things, like testing your audio and video settings, etc.
Aug 17, 2009 | GE Computers & Internet
MICROSOFT
This may have happened if you use some desktop clean up utillity.
To work around this problem, you have to provide the original installation source files.
For example, use one of the following procedures when you receive the error message:
• Insert the original Office 2003 program CD that you used to install Office 2003, and then click OK.
• Click Browse, locate the Office 2003 program installation folder on the network, and then click OK.
Mar 30, 2008 | Microsoft Office 2003 Basic Edition...
Olympus camedia c-300 zoom auto focus
hi, really surprising, how could you fix the problem, it will be fixed only by replacing the lens assy. so just go to olympus shop. good luck....
Jul 28, 2006 | Olympus Camedia C-300 Zoom Digital Camera
Adobe Photoshop 7.0 for PC Logo
21 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
