Canon PIXMA MP620 All-In-One InkJet Printer Logo
Posted on Jan 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have refilled my cartridges. All fefilled
I have refilled my cartridges. All fefilled cartridges work fine except the red. I have removed, checked it, and reinstalled it. It looks OK and reseats OK. What can I do to make it work?
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Jan 20, 2010
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2051025
Points
24677
I have never had success with refilled cartridges.
You may have had success, and that is great.
Replace the cartridges with OEM cartridges for best results.
Paper empty problem.after refill catridge
You haven't indicated make and model of your printer. Now, MY HP has been acting really weird when the head was damaged after a refill.
If your printer has a color and a black cartridge, check them removing one at a time. Sometimes after removing the damaged cartridge, the printes works, so all you should do is buy a new cartridge,
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
I have a canon pixma ip2770. I just had an ink refill for the first time but magenta ink won't work. I tried cleaning, deep cleaning, etc. but the other ink worked just fine except magenta. what should I...
Sometimes after a refiling they cover a small air holes on the top of the cartridge when replacing the label. remove the label completely and try again.
Also the magenta might have been to empty for a refill to work correctly. There is a lower chamber in the cartridge that air can get into and stop the flow from the top section. This link below can help in that case. http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps Regards GM
I have a HP PHOTOSMART 2610 all in one printer and have developed a printing problem. This printer has been working as it should up until just recently. I have been using the Walgreen's photo service...
Because is refill.When refilled a small gap is detached to make the refilling and it no longer recognize as the brand it use.
If you need more help come back.
Post / thumbs / testimonial are welcome!
1helpful
Dear Sir, We have canon xerox machine and our deler ask high cost for spares Ex. OPC - 6000, Tonar - 2350 also he told if you fefile your tonar it damege your machine due to this magnetic rod ,OPC can...
Please let me know the model of your machine. In general, if you are having print quality issues, such as lines dots or black patches, these are usually due to toner cartridge. Genuine Replacement of Toner cartridge is advisable.
However, you may get your toner cartridge re-filled, if its parts are working properly. Cartridge parts like OPC, PCR and magnetic roller can be replaced. Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine.
Hope it helps. Let me know if any clarifications are required!
CreativeTECH
2answers
Message on screen says ink cartridge problem remove and check cartridge - but cartridge is fine
remove the cartridge clean the gold contact on the back with alcohol and a q tip
HP6940 won't print red with printer test nor photographic image. With cartridge 1, I refilled it, and I could see some red oozing (along with the other colors) if I press a clean tissue to the head. With a...
I can only say that the preamble is with the ink cartridge. Just happens that red is one of the first to get clogged. Happened to me on the 95 ink cartridge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
HP 57 refill problem
You are doing nothing wrong. The nozzles are clogged. Try taking a clean syringe and put your finger on one of the magenta (red) refill holes. Fill the syringe with air. Put it on the second magenta refill hole and blow the air inside. That should force out the ink that has dried and that is not letting the new ink come out. You might have to do that several times. Sometimes, it can help.
If that doesn't work, go to a refill shop, they should be able to clean the print nozzles on your cartridge, no need to buy new ones.
old marine
old marine
ZJ Limited
ZJ Limited
