I have a malfunctioning DVRrecorder-player Model DMR-ES15 THAN TWO YEARS OLD. The problem. The machine displays the message- unable to read disc It then does not respond to any commands and of course does not function. I have re purchased a new unit. but would appreciate your answer if a fix is possible.
    Scholar:
  • 119 Answers
Buy a cleaner cd.it is a special cd with  a brush to clean the lense of the dvd /cd reader.it will take off the dust and dirt accumulated in 2 years
if this will not fix the problem..more than sure is almost nothing you can stiil do(the laser lense is damaged)
bye bye
Posted on Feb 12, 2008
Hello! I have a problem with a Panasonic DMR-ES15 DVD recorder. I have an error code E61. I tried all the solutions manual but did not work. I can not use it either as player or as a recorder. reset have a...
Hello.
I had a similar problem with my DMR-ES15 a little over 2 years ago, and, I too, could not find a solution. I resorted to sending it off to Panasonic for their 'out of warrantee' repair, for a hefty price. (I could have bought new, but really liked the features of the ES15.) Panasonic repaired it, and it worked well for another 2 years. Just recently, 3 weeks ago, it died it's second death, with the same issue. I wish I had a solution for both of us, but it seems it is a failure which cannot be repaired by the consumer. I had seen a previous post, which has a suggestion of looking for '2 failed capacitors', but no other information, not even where these capacitors are located in the machine. I enterd a post myself, but have received so solutions/suggestions, and I don't even see my post on this site anymore. I'm a little disappointed with 'Fixya'...
If I find any new information, I'll be sure to post it.
Feb 03, 2011 | Panasonic DMRES15 DVD Recorder
U61 Code will not reset - any suggestions?
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The Internet message said that person unpluged everything, then opened the cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back towards the rear of the DMR-ES15.
I assume that would void his warranty, but I am considering trying it since the time to have it repaired versus the replacement cost makes the possibility of a "self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
Aug 17, 2009 | Panasonic DMRES15 DVD Recorder
How I unloked my dvd because when I push open it displayed lock . The model is DMR-ES15 Also the DVD can't read de disc. I'd like your help in spanish thanks
any mobile & memory card and other many devises unloke code
simply connect it to the pc and open its file in note pad and
FIND YOUR PASSWORD
Jun 12, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr-es15
Pan. DMR-ES15 I WILL NOT RECOGNIZE ANY DISC I PUT IN. WILL NOT PLAY A COMMERCIAL DVD MOVIE. SEEMS TO HAVE STARTED WHEN IT COULDN'T FINALIZE A RECORDED DISC. HOW TO RESET?
Oct 28, 2007 | Panasonic DMR-ES10 DVD Recorder
U61 error code
UMM the DVD top lid uses FOUR screws. The entire DVD drive is bolted to the chassis with 3 screws.
Oct 14, 2007 | Televison & Video
Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
