Question about iRiver iFP-895 MP3 Player
Redgroove digital mp3 player voice recorder
Music playes for a few seconds then i get an error 41 message come up on the screen.
  • 1 more comment
  • ebbeh May 13, 2008
    get the same problem
  • Anonymous Sep 17, 2008
    Same here
  • Anonymous Nov 05, 2008
    i have the same problem..pls help me ..
  • 8,596 Answers
PC does not recognize player - sure you used the right driver?
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Posted on Jun 26, 2008
Formatting problems
older mp3 players cannot handle bitrates higher than 128 and you should not be recording them with variable rate either. I recomend, deleteting the card and start new with a standard bit rate
Feb 14, 2014 | Audio Players & Recorders
I have a Sony Walkman NWD-B105F MP3 PlayeR. It worked good until yesterday when I wanted to turn it on , the sreen of database/malkman did not changed. Therefore I formated the mp3 player and the result...
Hello every body,
I had the same problem and fixed it using a simple logic.
First Step: Format the Player using the PC. (click with right button on "Internal Device" and select "Format".
Second Step: On the "Internal Device", create this folders: "Music", "FM", "Record" and "Voice".
Third Step: Copy your music into the Music folder.
That`s it!! Go play
Jul 21, 2011 | Sony NWZ-B103FBLK MP3 Player
I have an option on my sandisk sansa fuze mp3 player for voice recordings. There is pre-recorded literature that I would like to download, but, I only know how to download these voice recordings under...
You can't. Audiobooks are just like music, and the Sansa treats them that way. Think of them as words spoken without music.
Voice recordings are made on the Sansa, when you use it as a digital recorder. You can record lectures, meetings, or notes to yourself, and play them back.
Aug 10, 2010 | SanDisk Sansa e260 MP3 Player
Manual
I have a coby mp-c855. I record my own voice by the following: hold the M button for a few seconds, scroll over to record and press play to start your recording and pause to end. To listen to your recordings in the future: use M button, choice voice options and press play. I have not figured out how to delete my voice recordings yet.
Jan 08, 2009 | Coby MP-C858 MP3 Player
DISK ERROR WHEN I TRY TO USE MP3
Double check p. 17 of the manual for a firmware upgrade, in case this message is caused by a db corruption, but the error may also be caused if your player is in the "lock" or "hold" position.
Link to the only manual on Centon's low-budget website:
http://www.centon.com/documents/mp3guide.pdf
-Tha Mp3 Doctor
May 28, 2008 | Centon Electronics MP4-001 MP3 Player
Displays error 41
Im having the same problem :| just with a different mp3
May 27, 2008 | Nextar MA933A MP3 Player
Redgroove mp3
upgrade to xp service pack 1
Dec 27, 2007 | Audio Players & Recorders
iRiver iFP-895 MP3 Player Logo
174 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
