Question about Whirlpool Duet GHW9150P Front Load Washer
Control lock light is on , washer won't start
I have tried unpluggling it and replugging . Still does not work.
  • 1 more comment
  • snorider Feb 12, 2008
    that worked! thank you
  • Anonymous Feb 12, 2008
    need help finding lock button...
  • tomskat Feb 26, 2008
    I have tried unplugging it. Did not work.
  • 3 Answers
Your controll is in child lock turnning power off wont fix find the lock button and push hold till light goes out
Posted on Feb 12, 2008
Wfw9150 door won't unlock
Try pressing the "end of cycle" button on the right side of the panel for 3 to five seconds. Wait for 3 minutes to open the door, do not force it. And you start all over again. Please reply as to the outcome. And if it is good you give me a 4 thumbs up rating.
Mar 14, 2013 | Whirlpool Duet GHW9150P Front Load Washer
It won't work with the "Control Locked" light on
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
Here's what the Duet tech sheet says to do:
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the Drain hose and Drain Pump
Filter is clear of foreign objects.
3. Check/ Replace Touch-pad/LED assembly.
4. Check harness connections.
5. Check the CCU.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Starts up with lights , water turn on then off error E5E
COULD BE SEVERAL THINGS FROM A MOTOR BOARD TO A LOCK SWITCH, SOMETIMES YOU CAN UNPLUG THE WASHER FOR 1/2 HR THEN REPLUG, THIS MAY RESET THE CONTROL GOOD LUCK
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet Front Loading Washer Won't Turn On
MY WASHER WAS DOING BASICALLY THE SAME THING. I HAVE A WHIRLPOOL FRONT LOADER MODEL #GHW9460PL0. MY HUBBY REMOVED THE 3 SCREWS FROM THE BACK OF THE WASHER, UNPLUG IT FIRST, AND TOOK THE TOP OFF. WE THEN CAREFULLY UNPLUG THE WIRES AND REPLUGGED THEM BACK IN 1 BY 1 SO U WONT GET THEM MIXED UP. WE THEN TRYED IT, AND THE CONTROL LOCKED LITE STAYED LIT. HE HELD THE SIGNAL CYCLE BUTTON IN FOR 3 SECONDS AND THE LIGHT WENT OUT. WE THEN TRYED RUNNING A CYCLE AND SO FAR SO GOOD!! GOOD LUCK!
May 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
204 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
