Question about Compaq 127770-001 127770-001 ARMADA E-500 3P850 128/20G 15.1 DVD 56K PC Notebook
Ac adaptor when i plug in my ac adaptor it does not charge new battery the green light does not come on i checked my adaptor on another one and it works it only runs on battery and says discharging when pluged in
    Scholar:
  • 163 Answers
Sounds like a DC jack or supply line issue. How old is the machine?
Posted on Feb 12, 2008
AC Adaptor not working in laptop
the problem is in your laptop...maybe it damaged too when you plugged your old adaptor. you should check your laptop for a repair...maybe it needs to replace tha spare parts that may have been damaged.
Dec 01, 2011 | Computers & Internet
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
When i go to charge my kodak M863 camera (in the wall or by USB) the green light flashes and then the red light blinks 3 times. please help this is the first time charging my camera.
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
Nov 14, 2009 | Kodak EasyShare M863 Digital Camera
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
Wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Computers & Internet Logo
73 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
