Tricity Bendix WDR1040W Front Load All-in-One Washer / Dryer
Problem for Tricity Bendix WDR1040W Front Load All-in-One Washer /...
Tricity Bendix BIW 105W Washing Machine
By ChrisGreen on Feb 12, 2008
HI - Have a Bendix washing machine BIW 105W - sometimes spins well, sometimes doesn't - can't seem to get up to full speed all the time and clothes soaking wet. The spin program (15) spins but doesn't spin the clothes dry at full spin, nor clicks into the off position. Program 4 allows the whole cycle and often spins the clothes dry. Any clues?
Solution #1
posted on Dec 12, 2008
Not Rated)
futureloginn
Rank: Guru
Rating: 89%, 392 votes
hi there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it
doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn,
replace it--but be sure to check the pump pulley before you change the belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
and may not function at all. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the washing machine to get to the
switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
the washing machine main housing near the door frame. Often you have to raise or open the top
or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the
motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing
machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the
clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to
burn out in one direction and continue to operate in the other. If this happens, you need to replace
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the
unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during
the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch
prevents the spinning action when the lid is up.
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Was this helpful?
Yes
No
Popular Solutions for Tricity Bendix WDR1040W Front
Questions and Unsolved Problems for Tricity Bendix WDR1040W Front
Do you recommend Tricity Bendix WDR1040W Front Load All-in-One Washer / Dryer?
Answer
Answer
Im having trouble getting the old solenoid off my tricity bendix BIW 105W washing machine to replace... (More)
Answer
we cannot get the door open. We did one load and the door will not open. We went through the cycles... (More)
Answer
Hi, I have a tricity bendix washer dryer its a wdr1040w there is no instructions as im in a rented... (More)
Answer
when I put the drying cycle on it rinses the clothes again 10 minutes before the end - what do I do?
Answer
when we set our wdr 1040w off on a no.4 cycle it starts to fill the drum,it clicks to move forward... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
