Question about Brother IntelliFAX 2800 Laser Fax
Check Paper Hi - The fax machine keeps saying check paper and will not work but there is paper in it and there always was paper in it.
  • 2 more comments
  • Briansong Mar 12, 2008
    "check paper" will not clear. There isn't any paper jamed in the machine. I opened the covers to be sure the paper was removed. Pressed "Stop", but the machine will not reset.
    Brother Intellifax 1270 "Check Paper" still appears eventhough there is no paper in the machine. All parts of the machine were checked and the carthridge removed.
  • Leather Head Mar 23, 2008
    paper will not feed to copy or print incomming fax
  • StanScan Apr 21, 2008
    Cannot feed fresh blank paper to print a fax or make a copy. Machine is trying to feed the paper, but makes a loud humming noise for about five seconds, then gives up. Displays paper jam message or check paper message. Paper is in input tray correctly. The noise sounds like something plastic/rubber is trying to turn, but is stuck.
    Scholar:
  • 78 Answers
Check paper can also sometimes mean a jam. Remove the drum unit from the machine and check for a piece of paper inside the machine.
Also with this machines feed path it can mean that a foreign object can fall down the back and obstruct the paper.
Posted on Feb 12, 2008
I have the same problem. Found the following on another site. Haven't tried either yet.
Subject: Brother Intellifax 1270 problems
Problem: Displays "Check Paper" and paper does not eject from machine entirely.
Solution: Replace "Off White" paper ejection roller with new "Grey" paper ejection roller. Cleaning the "Off White" roller will not resolve this problem.
Problem: Displays "Check Paper" and paper jams at Paper Ejection Sensor Actuator.
Solution: Found several defective PC-201 cartridges. Paper Ejection Sensor Actuator jams in window opening of PC-201 cartridge due to an apparent manufacturing defect of the cartridge. Note: Actuator works freely when recording paper cover assembly is open. Problem may be resolved by trimming the window opening by approximately 1/8" nearest the top of the window.
Posted on Mar 02, 2008
The machine always detect a paper jam without a paper?
Is there a small piece of paper over the paper jam sensor?
Feb 01, 2015 | Office Equipment & Supplies
Fax machine always saying load a paper,i tried to load a paper ,but the paper always going into different direction? what can i do
hi there!
the problem is in the feeder, or something that inside would cause the error, you can check the inside for cleaning or call a service center to do the job for you.
regards, fossildude
Oct 16, 2010 | Office Equipment & Supplies
Wont print,keeps saying check paper size
You need to call service, because the flapper of registration sensor is worn out, and fax cant detect right paper size.
Jun 23, 2010 | Canon FAXPHONE L80 Laser
Fax wont print,keeps saying check paper size,ive used same paper size for years
the problem is in flaper of registration sensor, it got worn out.
Replace it, and do the preventive maintenence routine ( check/clean/replace rollers, clutch,... )
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Paper jam
check all the paper sensors see if the sersor arm are still in place, clean all the sensors usually a photo diode type located at the boards.
Jul 29, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Faxing
Hi:
You may have removed the paper but the reason why it is still saying paper jam can be caused by at least two things.
If you removed the paper, but it tore while you were taking it out then a small piece could be blocking a sensor or a sensor flag ( a spring loaded finger that the paper has to activate as it moves through the machine) It's possible that a small piece of paper could be blocking a sensor or you may have disloged one of these 'flags' in the area where you first removed the paper. Go back and look closely in that area for a piece of paper or a sticking ''flag'. Until you do that the fax keeps thinking that there is something in the paper path and will keep displaying that message.
Andrew
Jul 20, 2008 | Brother FAX-575 Plain Paper Thermal
The printer keeps saying check paper - re load
check the paper, and reload it
check the paper sensor in paper tray, somtimes when you slide paper in to the tray it pushes under the sensor and holds it up, it is supposed to sit on top of the sensor and push it down
Jul 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Jun 30, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 2800 Laser Fax Logo
525 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
