Question about Westinghouse WST3504 Microwave Oven
Need help The power went out in my house and my microwave doesn't work anymore any suggestions on what i should do?
  • 2,130 Answers
1. Have you tested the outlet by plugging in something else and confirming that the outlet is good? If another device doesn't work in the outlet, then you have a bad fuse or breaker that powers that circuit in the house.
2. If power is OK, you probably have a bad fuse in the oven. You'll need to unplug the oven and remove the outside cover. Replace the fuse with the EXACT same rating of fuse of the original.
Please get back to me and let me know what you find.
- Jim
Posted on Feb 12, 2008
My microwave does not have any power. The electric outlet works, so I am wondering if there is a reset button somewhere. Model number: WP1000AP30-3. Serial number is FMD0210400437. Thank you.
If you have checked plug fuse there is an internal fuse but you have to remove cover to find it.if you do remove cover "MAKE SURE THAT IT IS UNPLUGGED" AS IT CAN KILL YOU"??????????????
Oct 21, 2017 | In Microwave Ovens
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
It just went dead. from working great(7 years old
Blown fuse. Remove the outside cover and should be located near the area where the power cord enters the unit.
Jun 03, 2009 | Amana Radarange Microwave Oven
I pushed the light button on my microwave and all power went out. It is not a breaker. Could it be a fuse?
You say all power went out but it is not a breaker. What power went out? In your kitchen? house? or just the machine? Can it be that you are plugged in a circuit that is protected by a GFI?
There normally is a fuse inside an oven on the floor. Unplug the device, remove the cover. DO NOT TOUCH THE SILVER CAN IN THE BACK - LETHAL.
Check the fuse with an ohm meter or contunity checker of some type.
If you need additional assistance, please let me know.
I hope this was helpful for you
a
May 14, 2009 | Hotpoint RVM1625 Microwave Oven
Electric went out to the house, it came back on, and the microwave inside light works, the display panel reads just a " : ", and none of the buttons work. I have tried resetting the breaker with same
Hi cschnur,
     It seems that you might need to replace circuit board.
All the above mentioned conditions refers to a faulty circuit board. You might have blown few Ic's.
Take a voltmeter, check the continuity. If you are aware of the Ic's, replace them.
Unless, look for a tech, a used board ( On http;//www.ebay.com ) or purchase a new one.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Apr 17, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
No power...
If the stove was on without the hood fan's being on, it could have put too much heat in the "innards" of the microwave. It may have opened the thermostat or thermal fuse located inside - either on the chassis of the microwave or or the magnetron. It will look something like the one in the attached photo. For helpful exploded view diagrams and to order any needed parts, you can visit the GE parts Web site or the Sears parts Web site at http://www.geappliances.com/shop/prts/ or http://www3.sears.com/ (the 3 is correct) In my profile, you can find a link to my site, where you can find critical safety & disassembly tips. Post back if you need more help.
Dec 23, 2006 | GE JVM1660 Microwave Oven
Westinghouse WST3504 Microwave Oven Logo
137 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
