Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite 7.0 cu. ft HE4 GETTING A CODE E 2
It will run fine for a couple of minutes and stop, then shows me an code E2.
Which means to call for service. What else can i do?
  • 1 more comment
  • GMUNOZ Feb 13, 2008
    The Model number is : 110.85861400
  • brian c
    brian c May 11, 2010
    Your model number will look like this: 110.123456789
  • brian c
    The thermistor (temperature sensor) is bad. If you post the exact model number, I will be glad to link you to a supplier for the part.
    You can locate the model number by looking:
    • On Plate In Door Well
    • Side Or Bottom Of Cabinet
    • Cabinet Frame Door Open
    • Back Upper Left Cabinet
    • Inside Of Door
    • Behind Access Panel
  • 589 Answers
The part number for your thermistor is 3976615, and can be obtained directly from Sears for about $30.
It is #42 on this parts list:
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00003&documentId=K0410034&modelNumber=11085861400&productCategoryId=0151200&brandId=0583&modelName=RESIDENTIAL+DRYER&backToLink=Return+to+Sub+Components
You may be able to find it cheaper from other sources.
If you want, I can look for other suppliers, just let me know.
Good luck.
Posted on Feb 13, 2008
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric Dryer......Starts, runs and drys but has a REALLY loud squeaking sound
Your drum rollers is in need of lubrication.
You can lube them with a high quality machine oil like 3inOne oil.
Please rate me
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
I OWN A KENMORE ELITE OASIS HE TOP LOAD WASHER AND I AM HAVING PROBLEMS WITH RUNNING A FULL CYCLE WITHOUT HAVING TO ADJUST THE LOAD A F 51 CODE APPEARS AND THE MACHINE STOPS. PLEASE TELL ME WHAT I NEED TO...
F51 MEANS BAD READING ON THE RPS SENSOR. COUPLE OF THINGS YOU NEED TO CHECK. IT'S A LITTLE COMPLCATED. IF YOU ARE A LITTLE MECHANICALLY INCLINE, I CAN WALK YOU THRU IT WITH WITH NO PROBLEM
BOYNISMO@YAHOO.COM 714-334-1998
Dec 06, 2009 | Kenmore Elite HE4 Electric Dryer
I keep getting the F21 code on my kenmore HE3t washing machine. What does it mean other than call for service?
The f21 code means that you need to clean the filter.
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Error Code E1
Usually when the thermistor is repaired the high limit is replaced, I dont recall the E 2 except a manual is under the console
Jun 01, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
192 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
