Question about Compaq Armada M700 Notebook
Battery for Compac Armada M700
I have a compaq Armada M700 PC notebook, and I changed the hard drive...since then the battery is not working any more, the light battery charge is on,but the battery is dead. What could be the reason, do I need to reset it or something like that?
  • Rich Collins Feb 18, 2008
    The battery on my M700 died, and would not charge, no leds light when test button pressed. After carefully opening the battery only at the corner where the test button is located, separated the halves unseating the white internal plug circuitry. After 2 mins. reassemble the battery, replace in laptop, and it accepted full charge. 100% success. Nothing to do with the hard drive, I must add.
    Rich
  • 39 Answers
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Posted on Feb 12, 2008
My Compaq M700 Armada , causing charging problem it run perfectly on direct supply from adapter but it do not charge battery. but was working perfectly few day ago....
hello,
Try removing battery and then re inserting. This can usually be done pretty simply by sliding lock to one side and the pulling battery out. This is under the laptop.
Hope this helps
Jan 08, 2011 | Compaq Armada M700 Notebook
Battery
Check New laptop battery, it is a worldwide retailer and wholesaler who provides all kinds of batteries(include Compaq Armada M700 batteries) and adapters for laptop.
Jul 08, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
My compaq armada m700 is having problem
this may be because the battery is dead so you may have to keep the charger attaached to the laptop for power. if this does not work then this means that the battery is no longer good so u will need to replace it.
please rate me. thank you,
May 23, 2008 | Compaq Armada M700 Notebook
Compaq Armada m700 battery
docboy, the battery on the M700 is locked in. Unlock it and pull UP on it. To put it back in you have to seat the end nearest the side of your laptop then push down gently on the end toward the middle. It will lock in and there ya go!! Hope this helps!
Jann
May 02, 2008 | Compaq Armada M700 Notebook
Help with battery location???
Try this:
http://www.mk-stuff.de/artikel/how_to_disassemble_a_compaq_armada_m700/
Apr 06, 2008 | Compaq Armada M700 Notebook
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Oct 31, 2007 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
My laptop armada m700 gets no power
the hard drive was damaged. Inside the drive, the tiny moving head took the hit. They really are not designed to take shocks like that. Many laptop mfgrs offer "industrial" duty laptops that have on-board shock absorption suspension for hard drives.
Aug 26, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
121 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
