Question about Zebra Z4M Printer
Zebra 4M Plus Pauses unexpectedly
We have a Zebra 4pm Plus that when printing a large label job, it will pause by itself with no Error on the LCD Display, with pleanty of ribbon and label paper withen the unit. If you Then hit the pause button to un pause, the job continues (somtimes pausing again depending on how much more it has to go).
The Printer is hooked up to a WinXP pro based computer via LPT port. Any ideas?
  • 1 more comment
  • plcalderaz Apr 29, 2008
    Anyone Have any Suggestions on this? Thanks
  • Anonymous Aug 12, 2008
    thanks
  • Anonymous Mar 17, 2014
    I cant seem to find a way to un pause it.
    Champion:
  • Zebra Expert
  • 285 Answers
Try to run the manual calibratio from the setings.
run "manual calibration"
move the ribbon out from the sensor (with the print head open) and take out 3 or 4 labels from the rollar and put that blank label paper unther the sensors on the left,
say "ok"
wen appear "reload all"
put the ribbon and the normal labels on the correct possition, and say "ok"
try to run sext the sensor profile.
save data (twice on "setup button")
tur off, and on again.
Posted on May 08, 2008
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Zebra S600 - Printer pauses after each printed numbered label, if I don't number them it works fine?
It sounds like your labelling software is re-sending the entire print job each time. Do some research with your software and see if you can change the defaults so that everything BUT the serial number is stored inside the printer, and only the new serial number is sent.
It's difficult to be more specific because every software package is different...
Feb 10, 2012 | Zebra Stripe S600 Thermal Label Printer
Pausing between each label print. It never used
Send this to your printer via serial or parallel
^xa^zc2^xz^xa^jus^xz
May 13, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Zebra 4m printer. Turn on and pause and error
You have a bad logic bd and it needs to be replaced our repaired.
Rory
Dec 20, 2009 | Zebra Z4Mplus Label Printer
Zebra 4M printer stopping due to error message
The printer is dirty sensor label or no label is calibrated. Turn off the printer and press FEED, CANCEL, PAUSE and turn on, release the keys to advancing the label, and let print be calibrated. Roberto Martinez Mexico bartech9@yahoo.com.mx
Feb 26, 2009 | Zebra Z4M Printer
Speed of printing barcodes
Generally the ZM 400 can cope with printing at the lower speeds when printing barcoedes that are the same. You may get pauses if the barcodes are sequential numbers or are all different, then the data to be transfered to the printer cannot cannot keep up with the printer and pauses while it gets more data. We have found that if you can select in your labelling software to print the barcode as a graphic, then it speed up quite a lot. It is a matter of matching your print speed and quality to match your expectations, sometimes you will just have to put up with the pauses.
Feb 02, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S300 printer pauses without printing additional copies
I Use driver from Nice Labels
http://www.nicelabel.com/downloads/nicedrivers/zebra seems to work fine
Dec 05, 2008 | Zebra Stripe S300 Thermal Label Printer
Stops printing after sending job
try to reset to factory defult,
run calibration and sensor profile.
if dont help,
it is possible that the power suply or logic board is faulty.
Jun 30, 2008 | Zebra Z4Mplus Label Printer
Zebra 4m
If you are in rewind mode and don't rewind the printer will pause while the rewind spool tries to catch up.
Jan 10, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4m printer
you can change the backfeed option under the driver settings, I would also turn you print speed up too (on same tab) it sounds to be set on 2.5ips, crank it up to 7ips or higher
best of luck
Oct 01, 2007 | Zebra Z4M Printer
Zebra Z4M Printer Logo
1,495 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
