Question about Brother FAX-575 Plain Paper Thermal
Brother FAX-575 Cannot receive
It keeps saying that there is a paper jam. I have taken the thing apart. There is no paper jam. I cannot receive anything.
  • Sherry Mar 14, 2009
    I cannot receive faxes. It keeps saying paper jam, and the is no paper anywhere to jam. Also I cannot get a decent fax copy.It looks like the ribbon gets bunched up.
  • 168 Answers
Check your feed rollers that feed the blank paper into the machine. Take a flashlight and watch the rollers to make sure the rollers are spinning and trying to feed the paper.
If the rollers spin, and it doesn't pull the paper in, then your feed rollers are either worn or dirty. I would try cleaning the rollers if they are slipping on the paper. My suggestion would if you can find this cleaner called GOO GONE. This is a bio degradeable product that won't dry out the rollers and it will clean them.
Put some goo gone on a paper towel, and see if you can clean the rollers.
If you still have other questions, feel free to post them here.
Good luck.
Hope this helps.
Mac.
Please remember to post a feedback and or a rating if I have helped with your question.
Posted on Feb 13, 2008
The paper in my fax 575 always get jammed when receiving a fax.
Rubber rollers in the paper path probably have lost their grip; the surfaces become glazed and slip instead of transporting the sheet as they should.
Gaining access to the paper path varies in difficulty since many later units may be partly snapped together and use few screws for assembly.
If you decide to attempt this, use a hard cloth and naptha (lighter fluid) to scrub the rubber rollers; this should produce some black smears on the cloth if the rollers are glazed. Don't use alcohol since this will dry them out further. Naptha is safe for most plastics and aggressive enough to cut the glaze. While you are inside, check to make sure there are no scraps of paper complicating things.
Feb 14, 2010 | Brother FAX-575 Plain Paper Thermal
I need amanual for Brother Fax-575 Also does it
Yes, the Brother Fax-575 does have answering machine capabilities, in fact it recommends using an answering machine on a shared line. To download your User Guide, click on the link below. Best of luck and thank you for using Fixya!
Greg
Brother Fax-575 User Guide
Nov 12, 2009 | Brother FAX-575 Plain Paper Thermal
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Phone line ports
HELLO, THANKS FOR YOUR REPLAY TO MY BROTHER FAX -575 , WILL BUY NEW ONE.THIS ONE IS OUT OF WARRANTY.COST MORE TO FIX THAN TO BUY.....
Nov 04, 2008 | Brother FAX-575 Plain Paper Thermal
Cartidge jams when trying to print a fax
I use to sell the generic ribbons. they have a lower heat transfer. the ribbon starts melting to the paper & causing all kineds of problums. Sorry to say you need to buy name brand.
Oct 10, 2008 | Brother FAX-575 Plain Paper Thermal
Faxing
Hi:
You may have removed the paper but the reason why it is still saying paper jam can be caused by at least two things.
If you removed the paper, but it tore while you were taking it out then a small piece could be blocking a sensor or a sensor flag ( a spring loaded finger that the paper has to activate as it moves through the machine) It's possible that a small piece of paper could be blocking a sensor or you may have disloged one of these 'flags' in the area where you first removed the paper. Go back and look closely in that area for a piece of paper or a sticking ''flag'. Until you do that the fax keeps thinking that there is something in the paper path and will keep displaying that message.
Andrew
Jul 20, 2008 | Brother FAX-575 Plain Paper Thermal
Brother 575
set the reception mode button to fax not fax/tel
Aug 29, 2007 | Brother FAX-575 Plain Paper Thermal
Brother FAX-575 Plain Paper Thermal Logo
184 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
