GREEN AND RED HUE IN PICTURE WITH CABLE OR DVD
AKAI 42" MONITOR HAS GREEN AND RED HUE IN THE PICTURE WITH CABLE OR DVD. TRIED RESETING DEFAULTS; ADJUSTING PICTURE, AND EVEN REPLACE VIDEO MAIN BOARD AND STILL SAME PROBLEM. HELP?
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Posted on Feb 12, 2008
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
Our Sony Grand Wega suddenly has a green-yellow tint.
IF IT IS HOOKED UP WITH COMPONENT CABLES (GREEN, RED, AND BLUE) FOR PICTURE AND RED AND WHITE FOR AUDIO, MOST LIKELY THE RED ONE IS NOT SEATED PROPERLY, CHECK BOTH ENDS THE ONE CONNECTED TO THE TV AND THE ONE CONNECTED TO WHATEVER THE SOURCE IS ( SATELLITE BOX, CABLE BOX ETC.
Oct 06, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Everthing that is supposed to be black comes up green
I just bought one of these that had the same problem, except it was the red that was bad. It is a bad connection on a surface mount connector going from the input board to the computer board.
I wish I had written down the connector location. Here is a picture (if this works). The red arrow points to the cable/connector that needs to be removed and cleaned and reconnected. This board is in the center of the monitor and under an aluminum cover (just pull it off).
Aug 13, 2009 | Akai PDP4225M 42 in. Plasma Television
42 inch vizio and the colors are way off mostly blue and green shadows reds and yellows are off and really bright.
Hi..
Check the owners manual and see if there's a place that allows you to reset to factory defaults.
Sounds like your color settings Hue--Saturation ETC are way off the mark
Jan 08, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Green hue on all inputs
Most likely there is a failure in the video processing. The flickering was from the failing components breaking down.
Your set can be serviced by an experienced tech who has spare boards and the facilities to service your set.
Jerry G.
May 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Dvd movies have green shade on tv
Check to make sure that *all* the RBG cables are properly inserted into the dvd player. We had the exact same problem for the past year only to discover that the R cable (for red) was not pushed in...hence, all dvd movies had a green hue to them.
Mar 08, 2008 | Televison & Video
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Green dvd
if dvd is a hdmi..and your using RGB cables..swap them around..it sounds like you have the cables misplaced..if that doesn't work..then swap out the dvd player and see if the replacement dvd player does the same thing
Jan 25, 2008 | Akai LCT2721AD 27 in. LCD Television
Image has red hue when connected via Composite cables...
Hell, the firest thing you should try and do is to clean all the connections with sandpaper-especially the connections which are on the TV. Good Luck!
Oct 07, 2007 | Aspire Digital AD-8091 DVD Recorder
42" plasma
if your using component cables check to make sure they are seated well
if so try swapping the blue and red if red is still bad you probobly have an issue with the SSB
Jul 06, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
407 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
