Wharfedale in car DVD player(model WCV2601)
Hello i have installed an in car DVD player in place of my old CD player. whenever i switch the ignition off and take the key out, the panel display is switched to stand by mode but does not turn off completely, the light is visible, is there a problem with the unit?
hope you would offer the best solution!
thanking you!!
  • Anonymous Aug 25, 2008
    Did you found a solution or get any answer on your DVD player?
I have the same dvd player but no remote any one know where to get one thanks
Posted on Jul 05, 2010
    New Friend:
Hello ...i have a wharfedale wcv2601 the dvd is not comming out ...any answears ...thanks
Posted on Aug 16, 2015
I have problem. not remote.........please help me.. 1servismobil@seznam.cz /czech republic/
Posted on Jun 08, 2009
Is the unit blootooth or touchscreen.
Posted on Jun 20, 2008
I am looking to buy the same unit how would you rate it??
Posted on Apr 20, 2008
Scoott - that is right but u loose ur memory i.e. when ur playing a dvd it will not remember last place :(
Posted on Mar 09, 2008
Sounds to me that you have the two positive power leads the wrong way round. 1 is a constant 12v supply that holds the memory when your car is off, the other is a 12v supply that powers the stereo only when your car is running, thus turning the stereo off with your car. try switching the two around. good luck
Posted on Mar 08, 2008
Addonics dvd/cd-rw
Sometimes this can be caused by settings or any hardware changes, but if you haven't changed anything probably not. I have had mine act like yours, I ended up installing a new DVD player.
Nov 05, 2017 | Addonics (AEMFR888D) DVD±RW Burner
New dvd writer recognised as old
Hello.
Go to Control Panel.
Locate System.
Locate your Device Manager.
Under your DVD/CD Rom devices, locate the old DVD writer. Select it. Right click and hit Uninstall.
Now scan your computer for new hardware, and install the new DVD writer with the discs it comes with, if any.
Nov 07, 2009 | Computers & Internet
I need to take out old ignition lock cylinder without key on 1989 toyota camry le -lost keys-bought locksmart replacement but it says old has to be in acc position to remove-
This is what the tech manual says.....
Ignition Lock/Switch REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable. If equipped with an air bag, wait at least 90 seconds before working on the vehicle. CAUTION
    Some models covered by this manual may be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Section 6.
  2. Remove the lower steering column cover. Unfasten the ignition switch connector under the instrument panel.
  3. Remove the screws which secure the upper and lower halves of the steering column cover.
  4. Turn the lock cylinder to the ACC position with the ignition key.
  5. Push the lock cylinder stop in with a small, round object (cotter pin, punch, etc.). NOTE: On some vehicles, it may be necessary to remove the steering wheel and combination switch first.
  6. Withdraw the lock cylinder from the lock housing while depressing the stop tab.
  7. To remove the ignition switch, unfasten its securing screws and withdraw the switch from the lock housing. To install:
  8. Align the locking cam with the hole in the ignition switch and insert the switch into the lock housing.
  9. Secure the switch with its screw(s).
  10. Make sure both the lock cylinder and column lock are in the ACC position. Slide the cylinder into the lock housing until the stop tab engages the hole in the lock.
  11. Install the steering column covers and connect the ignition switch wiring.
  12. Connect the negative battery cable.
Jul 26, 2009 | 1991 Lincoln Town Car
I dont know were the ignition wire is im trying to hook up a jensen cd player to my 1998 nissan sentra
Ignition wire is any switched lead that is off when the key is off.
In a 1998 Sentra, the wire behind the radio that is a switched power lead is BLUE.
Double check with test light or voltmeter.
Thanks for using FixYa - a FixYa rating for answering your FREE question is appreciated!
Mar 02, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
When i try to burn on hp1040e dvd burner it wont recognize the dr
you may not install the proper drivers of your burner, install it again and use some other burner application like nero cd burner etc.
Feb 10, 2009 | HP DVD1040e DVD-RAM Burner
Fn+f5 does not work. unable to switch between screens.
Thanks for your reply. I was working outside the house all day and we went out for dinner after to wind down.
I'll get back with you with a link if I can find a driver now that I know you have me and I have your model and series number.
Regards,
Worldvet
Jun 09, 2008 | Toshiba Satellite 3000-S353 3005-S303, and...
New installed cd player wont work
did tou wire the red line to 12volts when the ignition switch is in the acc or on position- and the yellow wire is powered at all times regardless of the position of the key switch?
Apr 02, 2008 | Aiwa CDC-X227 CD Player
CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Nov 09, 2007 | Computers & Internet
PROBLEM
Hold down 1 on the remote with the CD tray open. Should reset firmwire
Jun 26, 2007 | Philips DVD 622 DVD Player
Televison & Video Logo
1,648 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
