Question about HP 1020 Plain Paper Thermal transfer Fax
HP Fax 1020
I have a HP fax 1020 fax machine that has never been used. I pluged it and there is no sign of power, I have tried different power cords with same results. Your help is greatly appreciated.
Thank you,
Vincent
  • hgallaway Feb 14, 2008
    There is no on/off switch on this model as fas as I can see, I have checked several times.
  • 106 Answers
You have a small swith on/off from bottom of the printer check it
Posted on Feb 12, 2008
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
Problems with sending and receiving FAX
HP FAX ISSUES
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
Faxing problem with HP Office Jet 7130 all-in-one
hi-
chances are you need to change the setting on you hp printer, i mean the fax settings for it and by the way have you tried reseating or unplugging the wire that connects from the wall to your hp office jet? try to unplug and replug it then try sending another fax, update me for any unusualities, thanks!!
May 20, 2008 | HP OfficeJet 7130C All-In-One InkJet...
Tip
Try hard reset to clear most software lockups.
step 1: unplug cord step 2: plug unit in. Press and hold asterisk (*) key while dots scroll across display step 3: release (*) key when "all memory init" message appears step 4: unplug again step 5: plug unit in. Use L/R arrows to select country. Enter. Select language. Enter. step 6: Use Menu to set # of rings; volume.  Record message; Select TAM/FAX
on Aug 22, 2008 | HP 1020 Plain Paper Thermal transfer Fax
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Busy, try later error won't go away
depending what rollers and how you did it, you probably have 'spun' a clutch out of position so it can't find it's 'home" position, and keeps on trying. If it worked before cleaning and now it doesn't you've definitely broken or dislodged something like that.
May 25, 2009 | HP 1020 Plain Paper Thermal transfer Fax
I have a hp fax 1010 problems sending receiving
Are you plugging the phone line into the line jack or the phone jack on the fax machine, it should plug in to line. Also try and unplug/replug the units power cord as well as trying a different phone jack location.
Mar 25, 2009 | HP 1010 Plain Paper Inkjet Fax
Hp fax 1020 will not feed paper in
About to junk my hp 1020. Has not fed paper for some time. Used to do it one at a time by hand, but now won't at all. Any suggestions?
Aug 28, 2008 | HP 1020 Plain Paper Thermal transfer Fax
HP 1020 fax
From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
ANSWERING MACHINE (TAM) HP 1020 FAX
Please ring 1 300 888 423 who will give you an answer for free!
Jan 27, 2008 | HP 1020 Plain Paper Thermal transfer Fax
HP Fax 1020- Answering machine off
Please ring 1 300 888 423 whowill give you an answer for free!
Jan 06, 2008 | HP 1020 Plain Paper Thermal transfer Fax
HP 1020 Plain Paper Thermal transfer Fax Logo
95 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
