Question about All-Pro Forced Air Kerosene Space Heater SPC-K75
60,000 btu All Pro At start up,it "tries" but shuts down with smoke
I have checked the ignitor, it's working. Cleaned the filter. Removed the spray nozzel and lines, checked for any obstruction and found none. The heater is one year old and just developed this problem. It isn't even used on a construction site, just in my garage. I replaced all the fuel, no help. It sounds like the motor is running alot slower than it did when it was working. The motor fan spins easly and it not binding. Any suggestions other than buying a new heater?
Thanks
Bob
  • 2 more comments
  • garyperren Dec 09, 2008
    PK 60
    Turn on the switch. Sounds like the igniter hum (no motor or fan engagement). Saftey shuts off unit
  • agita Dec 23, 2008
    pk 60a (t) same thing mine hums then shuts off on overload. was going to change igniter, but not sure that is the problem.
    bbt
  • Anonymous Jan 08, 2009
    I have the same problem. I just went out and spent 50$ on a new igniter and the problem is still there. When i plug it in, the igniter turns red in then the fuel sprays with no affect and then it just shuts off. I was wondering if it had something to do with the fuel or air adjustments on back. Andrew
  • Todd Gibb May 11, 2010
    Does this unit have a solid state relay hooked to the motor? I can't tell without a model #.
Check to see if the flame indicator (photocell) is dirty. Sometimes soot or dust will cover the lens and need tobe wiped off.
Also when these have been sitting for awhile mice or other rodents can build nests inside the housing which can cause problems as well as afire hazzard.
Posted on Jan 22, 2009
I have a 70,000 btu reddy heaterthat after 2 mins shuts off it has a good eye new electrode ....but the motor seems warm to touch
the fuel pump may be plugged up and that will overload the motor..also if the flame on does not occur the unit will shut down for safety..need to check the fuel nozzle and see if it sprays while trying to start.. if not it needs cleaned/replaced.. can be cleaned with carb spray and wiped off .. remove and look at the filter in the back of it.. may be blockked up..
Feb 02, 2014 | Reddy Heating & Cooling
I need a diagram for aqua pro 600 heat pump
if voltage to unit and calling for heat check ignitor and gas
Jul 27, 2012 | RTO Aqua Pro Systems Pro 600 60,000 BTU...
I have a 60,000 btu kerosene heater its getting fuel and the glow plug turns on but still wont fire up n shuts down. what would cause this?
Well it is getting fuel but is it atomized in very small droplet form? If so is your igniter close enough to ignite the fuel? You see these spray a very fine conical mist under high pressure, if the mist is not defined or conical it sprays past the igniter. If it is fine and cone shaped it could be the positioning of your igniter. Please check both by removing the top section of the heater and watch what is going on in there. My thoughts are a bad nozzle and if you replace it pay attention to spray angle and GPH rating printed on the side of the nozzle.
Dec 22, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Heater wont start.Fan goes, Starts to heat, then blows a couple clouds of smoke and dies. Ive cleaned filter, new fuel. Cant figure out what adjustment I should be doing. Glow Plug? What else?
take the shield off and see if it burns with more combustion air. If it does then the heater isnt getting enough air. look for a shutter or set screw near the burner that should be the primary air adjustment. sounds like you have been working on the fuel side already. You may check the orfice to see if it is partially blocked, use a safety pin and gently **** it out. also check the burner tube
Dec 07, 2009 | Reddy Heater 60,000 BTU Kerosene...
I have a 75,000 btu all-pro forced air contruction kerosene heater. Lately its been running for a bit before ignition and then a lot of smoke and flames. After it settles down it heats fine. Today it...
Just in time for a spring cleanup! Sparkplug----- fuel filter-- 2--air filters vanes in the pump assembly which you can purchase at your local lawnmower repair shop ,or they can order them....
Dec 02, 2009 | All-Pro Forced Air Kerosene Space Heater...
70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Feb 09, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Jan 22, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
All-pro 60,000 BTU multi-fuel
it looks like a blockage somewhere in the system, does it have a exhaust vent check its clear and also check the burner if its clear.
Jan 19, 2008 | Heating & Cooling
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
111 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
