Question about Motorola Mobility SLVR L7 Cellular Phone
Can't see faceplate.
Phone works,but can't who's calling and or to get my directory. phone not even 6 months old. its a motorola slv 7. please help. thanks. ann
  • 4,102 Answers
Do you mean you cant see the screen give me more info then i can help you further.
Is it that you cant see the name on the screen also whats wrong with screen let me know ok
Posted on Feb 12, 2008
My Motorola WX416 quit want to get a new phone?
6 months old? WARRANTY? Take it back to the dealer and ask for a new one. That's what I'd do.
Dec 04, 2014 | Motorola Cell Phones
Need to unlock Motorola Razor V3xx to change from Cingular to work on Verizon
See response here: Need to unlock Motorola Razor V3xx cingular to work on Verizon
Mark
Motorola Support
Apr 12, 2014 | Motorola Mobility RAZR v3xx Cell Phone
How do i customize ring tones? (i.e. use my own music, etc.)?
Please find steps to customize ringtones.
Note: in order to be able to use this method one has to have two Motorola phones: the W510 and an older one that isn't ringtone-locked (I tried a V190 and and RAZR V3 and both worked).
First create a backup directory on your drive and call it something like "Original Motorola W510 audio directory". The name doesn't really matter as long as you can find it later if you ever need those files again. Next install the ringtones you want to have on your W510 to the old uncrippled phone.
Then follow these steps:
Step 1 - Connect the W510 to your computer via USB or Bluetooth
Step 2 - Fire up P2K (latest version)
Step 3 - In the right pane navigate to P2k:/c/mobile/audio/ on the W510; in the left pane navigate to the backup directory you just created on your hard drive. It will be empty.
Step 4 - Select all the files in P2k:/c/mobile/audio/, right-click and select "copy", the files will be automatically pasted in your backup directory.
Step 5 - Delete all the files in P2k:/c/mobile/audio/. Once this is done the "audio" directory will have vanished so it's possible that P2K will crash, this is not a problem.
Step 6 - Create a new directory on your disk, name doesn't matter. Unplug the W510 from the computer and reboot it (the phone), then close P2K (if it hasn't crashed already) and plug the older Motorola phone into the computer, wait for the computer to recognize the new phone, then restart P2K. On the right pane navigate to the old phone's audio directory (same location as on the W510), on the left go to the new directory you have just created.
Step 7 - use the method described in Step 4 to copy all the files in the audio directory to your hard disk. *Do not erase any files in the old phone's audio directory*
Shut P2K down and unplug the old phone from the computer. Plug in the W510 and wait for the computer to recognize it. Once this is done fire up P2K once more.
Step 8 - Remember that the audio directory on the W510 is gone, so you can't navigate directly to it, you need to create it first. In the right pane go to /c/mobile/ and select "New Folder" from the menu at the bottom of the pane. Name the new folder "audio" and navigate to it.
Step 8 - In the left pane navigate to the new directory on your hard drive that contains the audio files from the old phone.
Step 9 - Copy all those audio files to the new audio folder you just created on the W510.
Step 10 - That's it, your W510 now contains every single ringtone that was on your old phone and all of them now have the "apply" option enabled so the W510 will now accept any of those sounds as a ringtone.
Unfortunately the W510 still won't accept sounds from any other source than the old phone but as long as you're able to get those those sounds (inclding custom sounds) to register as ringtones on the old phone you'll be able to transfer them to the W510 using the method described above. It's a little tedious but there ain't no such thing as a free lunch is there
Thanks
S
Nov 21, 2009 | Motorola Mobility W510 Mobile Phone
As Above
It your board is having a defect, call AT&T you should still have warranty since it only 7 months old. they should be able to replace your phone free of charge.
-Charlie S.
Jul 18, 2009 | Motorola Mobility RAZR V3
Dynamode Internal Fax Modem 56K
i had same problem trying to receive faxes until i changed phone connections.
according to a motorola manual (link below) this has something to do with being connected to a "proper analog phone line".
i had the phone line running from wall to a newer gateway (maybe 8 months) dec 07 to a maybe 2 year old compaq. kept getting that loop current error on the compaq when trying to receive a fax until i elimated the gateway connection and plugged the wall right into the compaq.
here's a link that might help: http://downloadmirror.intel.com/12655/ENG/Motorola.htm
see section 6, troubleshooting. hope this helps...
Jun 27, 2008 | Computers & Internet
Screen not working
Dear Sasselle98,
The problem can and probably is hardware related and will need repair. (flex cable, lcd screen etc)
Nevertheless since the phone is only 6 months old it is under warranty and will be fixed at a motorola repair service center. So do that since it is the manufacturer's fault!
Regards
Mar 12, 2008 | Motorola Mobility W375 Cellular Phone
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
My new Razar V3a makes buzzing sound
If the buzzing is coming from the keyboard then it's a known problem/feature. Got the same on mine when the keypad is lit up, so rag Motorola, who said sorry, known feature with that model.
Aug 29, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3 - Problem With Buttons
my son's phone is about 7 months old too and today when i turned it on it would not go past verizon welcome screen, no matter what. i don't use this phone, but if your volume controller is on the keyboard it could be that the keypad is going bad, which appears to be common with the razr. if it is the keypad, you can pick up a keypad flex cable for about $12 on ebay, and it's a very easy fix, but if it's just 7 months old, i'd return it under warranty, that's what i'm going to do. Let me know what you find out. I just think it's really strange that our phone suffered no damage of any kind, it just quit.
Jul 29, 2007 | Motorola Mobility RAZR V3
Razr phone problems
000000 master reset 6 zerros
May 18, 2007 | Motorola Mobility RAZR V3
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
